205 - Engine Oil
    Cub
    Cub is offline
    Member Cub's Avatar
    SYDNEY
    82
    Icon5 205 - Engine Oil
    Hi guys,
    Need some urgent help!
    I've just realised that my 92 205 is dangerously low on Engine Oil, however because I havent had the car for long enough I dont know the engine bay AT ALL! I know its terrible but I just havent had a chance to read my Haynes manual yet.
    Can someone just tell me quickly where I top up the engine oil???
    CUB
    Oct 2000
    Auckland, New Zealand
    533
    Assuming they are similar to other 8valve XU motors, the oil filler cap is sort of like a black plastic tube that sits in between the injection manifold, with two rubber hoses coming out each side and when you take off the cap there will be a gauze.
    So basically look for a black plastic tube/cylinder that is sitting around the injection manifold with two rubber hoses coming out each side.
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Quote Originally Posted by Cub
    Hi guys,
    If it's original it will be via the black plastic cap on the passenger side of the inlet manifold. The top just pulls out of a small "cup". Be careful that you don't break it if its not broken already .
    Will
    Cub
    Cub is offline
    Member Cub's Avatar
    SYDNEY
    82
    THANKS FOR THE REPLY GUYS!
    Much appreciated...have learnt a valuable lesson....never leave my Haynes manual at home!
    CUB
    Sunshine Coast, Buderim
    23
    Default also check your oil level frequently
    I've found my 205s is thristy. Ran completely dry on my first 205 and was not a nice feeling.
