405 ABS brakes
Results 1 to 7 of 7
Thread: 405 ABS brakes
    Dec 2004
    14
    Default 405 ABS brakes
    i don't know how but i'm driving a 405sri 93 series 2
    it's a big change from the old volvo 245 brick (great car)
    how can i tell if it has ABS brakes?
    is there a good web page on the 405??
    thanks
    Oct 2000
    Auckland, New Zealand
    533
    According to UK-specification, the 'Series 2' SRi's had ABS as an option.
    If it has be optioned, an ABS warning light should flash when you start the car.
    If that doesn't indicate whether you have ABS, surely a sudden stop should make it clear?
    Sydney NSW Australia
    137
    Quote Originally Posted by Louis
    Alternatively, look inside the bonnet immediately behind the RHS headlight and you will see the ABS booster pump with six hydraulic lines attached to it... clearly marked ABS.
    Dec 2004
    14
    Default thanks
    i'll have a look for the pump
    thanks
    Fellow Frogger! pips's Avatar
    Dec 2004
    Behind you
    487
    There will (should) be those metal brake lines coming out of a block. The block will also have initials in relation to the respective brake, ie: FR, FL, RR, RL. Front Right, Front Left...etc.
    This is off the top of my head as I just started to get into pugs and saw my one today with ABS.
    pips
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Why not just drive it onto some grass, preferrably wet above 10KPH and stand on the brakes.
    You'll soon find out if you've got ABS or more correctly if you have, if it's working as the pedal will hammer under your foot.
    Alan S
    7,483
    I agree with Alan. Just stand on it, half on the dirt, from 80km/h. You'll soon find out.
