Strange engine noise 180
Results 1 to 13 of 13
    Fellow Frogger! Industrie's Avatar
    Brisbane Australia
    635
    Default Strange engine noise 180
    I've just noticed a noise my car seems to make at spot on 3000rpm. Not 500 above or 500 below. Everytime the engine hits this figure there is a kind of metallic whine. It's very hard to describe. I'm not sure if it's some kind of induction, or what. It occurs whether revs are increasing or reducing. If I put it in neutral and keep the revs directly on 3000 the noise will continue until I change the rpm.
    Anyone else had this with the 180?
    Dec 2004
    2
    Default Noisy Engine?
    I had a similar noise on my 138, it turned out to be the water pump!
    Its worth checking out.
    I got my pump replaced under warranty, what is interesting is that it took three months before they fineally discovered the area of the noise.
    cheers
    Tony
    Member Griff180's Avatar
    Sep 2004
    Perth
    67
    Yeah I get the same noise ! They haven't been able to locate the culprit yet !
    2004 Black 206 GTi 180
    Brisbane Australia
    635
    I had another listen to it last night. I think the noise is an additional raspy sound to the engine noise. The mechanical equivalent to having your lungs full of mucas.
    Fellow Frogger! Rusty@'s Avatar
    234
    Icon11 Hope this helps
    I recall reading an article on the 206GTI website, culprit being the engine cover vibrating at similar revs.
    http://www.206gti.net/enginecover/
    Hope this helps.
    Current: '06 Iron Grey 407 SV HDi '02 Silver Audi S4 '05 GTi 180
    Previous: '05 Aegean Blue GTi 180
    Previous: '04 Sahara Gold 206 GTi
    Previous: '95 Silver 405 SRDT (Fantastic Tourer)
    Jun 2004
    8
    I had something similar in my 180. Got it checked out and it turned out to be an exaust shield that was vibrating at 3000rpm. Also got told to look out for the engine cover vibrating... haven't had that as yet but the dealer said it's an easy fix if it happens
    hope this helps
    2004 206 Gti 180
    Jun 2004
    8
    BTW they were able to fix it by "realigning and tightening" the exaust heat shields.
    good luck
    2004 206 Gti 180
    Fellow Frogger! Dr Nick's Avatar
    Jun 2004
    155
    Quote Originally Posted by Dicko180
    hope this helps
    Thanks for the info Dicko!
    I also get this strange rattle-type noise but only when the engine is cold and when it's at a particular rev range. I've asked the guys at my dealership to try to listen for it while it was cold but they couldn't hear anything. I might ask them to try tigtening the shields on the exhaust based on your info.
    It's not the engine cover in my case. I've removed it and taken the car for a spin without and still got the noise.
    Nick
    Sep 2004
    Perth
    67
    I'm in exactly the same boat as all of you. I had the fix done(apparently) but the noise is still there. I also have a rattling noise coming from the clutch too that they said was corrected but I still get that noise too, although not as bad. It's going in for it's recall on the 31st so I'll get them to check it out again for me.
    1000+ Posts mr bern's Avatar
    Feb 2003
    Melbourne (or touring)
    1,152
    If it's the engine cover, you'll find that it resonates at exactly 2800 rpm (in the 138 -- can't see why it should be any different in a 180), which corresponds pretty much exactly with 40 km/h in 2nd, 60 in 3rd, 80 in 4th and 100 in top. Pretty much without exception, most 206 drivers couldn't give a rat's for the coincidence of this audible cue, and many with other priorities find rather that it simply interferes with the subbie. I quite miss it since I fitted my Devil exhaust ...
    MY15 208GTi
    previously:
    MY10 Sportium HDi6 and 1.6L auto
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    MY5? Simca Aronde 90A
    QUICK! MORE BREAD, MORE CIRCUSES!!
    Sep 2004
    Perth
    67
    The noise is definitely not the engine cover as I driven with the cover off and it's still there.
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Quote Originally Posted by Griff180
    The 180 cover is different anyway ?
    - xTc -
    Now this is a .sig
    Sep 2003
    North Parramatta
    3,997
    Yes, the 180 cover is definitely different to the 138 - no vibes on mine. I miss it too, Mr Bern - I was quite partial to the note it made.
    Griff, are you sure it's not the extra induction noise that seems to appear rather rudely when that second valve opens on the inlet pipe? You know, that rabbit warren-like extra 2 metres of hot plastic...
    It's not exactly metallic, but it appears to be at about the same point on my car.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
