504 dash warning lights
Results 1 to 10 of 10
    Jul 2004
    803
    Default 504 dash warning lights
    Hi everyone,
    On my 75 504 lti, theres a little red round light above and in between the rpm and the middle cluster. It comes on just before starting (like when u have it on accessories) and when i give it too her. Ive asked a friend (shobbz) what it was, he seems to think its the oil light. Can anyone confirm this, and tell me why its coming on at high rpm? Forgive my limited knowledge on the 504, I havent had much experience with the car, but with a flying background i know red lights that come on are bad lol.
    James.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    12,266
    there are 2 red lights at the top of the 504 dash
    the one to the right id for the alternator charge which is supposed to come on to warn you that it isn't charging
    the oil warning light from memory is actually in amongst the guages in the where you have the fuel and temp
    on one side will be one for oil and the other will be the high beam warning light
    the other red light is for the handbrake warning light
    then down the bottom will be an orange light for the choke warning for carby cars
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! Peter J's Avatar
    Jul 2003
    Dubbo NSW
    198
    Hi James,
    I think that light you are talking about is the brake pad wear warning light. 504 brake pads are fitted with a wire that when the pad wears down too low it creates a circuit and sets off that light on the dash. Check your front brake pads for wear, or otherwise may be a fault in the circuit.
    Do you have an owners manual. It explains that. If you haven't got try ebay as they often turn up their. Type in Peugeot and it should find any available.
    Regards
    Peter J.
    PJ
    Oct 2000
    Auckland, New Zealand
    533
    Here is an image of the cluster in my old 504 Ti.
    I think Peter J might be on the right track with the brake warning light.
    12,266
    the handbrake light is the same light used for brake warning or pad wear
    when brake fluid is low or pads are getting close to the end the handbrake light will light up
    later 504's had the brake warning light to the right of the dash on the actual dash panel along with a hazard warning switch and rear demister so depending upon which model 504 it is the lights may be a little different
    the other red light is the charge light which in most 504's doesn't seem to work even though it should to create a circuit for the alternator to be able to charge
    1 x 2018 3008
    Jul 2004
    803
    Hi guys,
    Just to confirm, the light im talking about is the one above and to the right of the main cluster gauge. Also while im at it theres two knobs just above the steering wheel, i know the one on the right controls the dash lights, but whats the other one for, i haven't figured out what it does, if anything.
    Thanks for all your replys so far!
    James.
    2006 Peugeot 206 Xt
    Jul 2004
    CLARE SA
    2,324
    Thje one on the left is a feng shui adaption, first pioneered by Peter Brock to bring better balance to the instrument cluster. It has no other function except in the extremely rare 504 ssssst, in which it is used to turn on the after burner, only needed when drag racing against fighter aircraft.
    ed ge
    Nov 2001
    1,640
    Quote Originally Posted by James504
    Hi guys,
    James.
    THe light is definitely the brake warning light, James. It will come on:
    1) when the front pads are badly worn (don't ignore this, you might end needing new discs if you do)
    2) when the hydraulic fluid level is low (don't ignore this either - you might be up for a new car or a funeral if you do)
    3) when the handbrake is on
    4) when the leads to the front pads come adrift and short out on any passing piece of car bodywork.
    My bet, from your description , is that we are probably talking about 1 or 2 above. Its always best to treat this problem as 1 or 2 above anyway, unless you can prove it otherwise and get it fixed. The consequences can be very unpleasant!
    As far as the two knobs go, the right hand one is the instrument panel light rheostat as you suggest. The left hand one was for resetting the trip meter , but its function is replaced by a knob on the speedo face on most Australian cars.
    The oil light, by the way, is the red light under the fuel guage with a picture of an oil can above it.
    Rod
    Rod's Home Page
    Rod's car page
    Fellow Frogger! Ranger's Avatar
    Launceston Tas
    143
    a couple of pics from the 504.org site the model shown has a clock instead of a taco but the lights are in the usual positions, hope this helps,
    Cheers Ranger.
    Attached Thumbnails Attached Thumbnails 504 dash warning lights-manuelus1974-page19.jpg   504 dash warning lights-manuelus1974-page21.jpg
    "The defendant is no gentleman, but that is neither here nor there. We find for the defendant, much as we dislike him." A.P. Herbert
    12,266
    Quote Originally Posted by Ranger
    Cheers Ranger.
    that's ok but we didn't get hazard lights on 504's here till the later models
    it think hazards arrived in about 77/78 on 504's
    1 x 2018 3008
