504GL auto trans questions
    Jul 2004
    AUCKLAND NZ
    50
    Default 504GL auto trans questions
    Hi there
    my 504 with the 3 speeder is leaking big time, though only when parked facing uphill. change down is a bit clunky at times otherwise it shifts fine. Is there anything that the basic diy-er can do on these? am too broke to take it to a mechanic.
    thanks for any help.
    patrick
    auckland nz
    Perth Western Australia
    2,694
    Default 504 auto trans ?
    Quote Originally Posted by 74504
    Hi there
    patrick
    auckland nz
    Patrick,
    Allow me to suggest a 50c possible fix.
    Is the auto trans overfull? Use proper procedure when checking ie when warm and trans in Park. If it is the BW 35 box, it's only a half litre variation between Low and Full. ....
    Is the leak coming from the speedo cable? If so get a seal and O ring kit for the cable and drive gear assembly. Easy job for a bloke like yourself and a Kiwi to boot!
    Once again, if it's the BW35 box the smooth operation requires correct kick down cable adjustment or the more complicated band adjustment. At this stage don't concern yourself too much with this. Besides IMHO when you can detect the changes in a BW35 it means it's working OK !
    Try the new seal kit, wash everything down and watch.
    Simon's Avatar
    6,203
    Or you can try the freebie solution that was offered by a Ford dealer to an owner whose 12 month old Falcon was suffering a similar problem. Park the car so the nose faces down hill.
    Check to see if the fluid is the right level first, as that could be causing the erratic changing.
    12,266
    does the car lose drive or pick up revs like it is slipping when cornering ?
    if so the fluid level is down
    i would drain and put new oil in and see how it goes from there
    if that doesn't help then waht is needed is info on what box it has
    it could be either a borg warner or a ZF
    check the cooling hoses to make sure they aren't leaking fluid as that is usually the first place they will leak and the 2nd place will be the sump on the tranny
    park the car up on a gutter if you don't have ramps and clinb in under the car and have a close look around to see where there is fresh oil
    the other thing you can do is take it to a car wash and jack it up and give it a damn good clean under there before checking to give you a better idea on where it may be leaking from
    if it is a ZF box then a new filter may be in order
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jul 2004
    AUCKLAND NZ
    50
    finally got a chance to crawl under and have a look. it's a borg warner box and it looks like the leak is coming from the speedo cable seal (at least I guess that's what it is, at the rear). will get a seal kit and hope.
    thanks guys.
    Patrick
