Jumping speedometer
    melb
    4,379
    Default Jumping speedometer
    Hi guys
    Amoungst the many little quirky problems with my car, the latest is a tad annoying.
    When in neutral the speedo stick thing keeps jumping up & down.
    Why?
    Can incompetant people like me fix it?
    Is this something i should worry about or live with?
    Much love
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Quote Originally Posted by purrr-geot
    Hi guys
    Why?
    Much love
    Asanka - In neutral (& clutch pedal out) the idel of the engine turns parts of the gearbox over, but no drive forward as its not inn a gear. Unless its really a problem, I would live with it. - Chris
    ... ptui!
    melb
    4,379
    my main worry really is why this has happened all of a sudden
    Any idea on the reason for this happening now & not 5 years ago??
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    Default jumping speedo
    Ah ( he thought ) chronometric speedos again.
    No ( thinks again ) worn cable, strand catching causing flicking of needle.
    No ( light dawns) these are funny Pugs with the diff in the wrong end.
    Funny computer driven electrics ( should read excentrics!) send to "specialist having some knowledge of broken circuit boards, poor earthing, intermittent capacitor discharge, pulsing transistors and other funny little green men running around in the computer box picking up errant signals just to confuse the driver.
    The 407 kept telling me I had a flat tyre. Not good at +110kmph.
    Bon chance
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    I had a problem like this in my Honda (I know, I know, shouldaboughtapug ) Well sorta, happened whenever at speed, not just in neutral. It was a dodgy speedo cable, not so much the cable itself, but the cable was a two-piece unit and the plug thing that connected the two halves together was worn out, causing the cable to flex and twist while spinning.
    You'd think the speedo cable spinning would be independent of gear selection (or lack thereof)
    I can imagine the speedo cable routing would be really 'interesting' given the car was designed for LHD
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    When in neutral the speedo stick thing keeps jumping up & down. Why?
    Turn the music down !!!!!
    - xTc -
    Now this is a .sig
