Urgent help for newbie! should i have a airflow meter?!
Results 1 to 13 of 13
    Dec 2004
    dorset uk
    7
    Default Urgent help for newbie! should i have a airflow meter?!
    hey guys found your site on google! just brought myslef a pug!
    its a bit loud and in your face but a giggle to drive! i have a problem tho! i took it for the mot and it failed the emmisions test. the co2 level should be about 1.5% and no more than 3.5 and its up at 11.5!! now i dont know much about the french engines i have allways delt with vauxhall(opel/holden) but it looks to me if there has been a airflow meter removed but i have the co2 adjuster on a plate and the airflow meter i try'd doesnt fit! anyhelp would be great! im wantin to get her sorted asap!
    heres some pics!
    THANKS
    Dec 2004
    LONDON/ UNITED KINGDOM
    9
    Icon14 cable
    that cable in your hand looks like the one that is connected up to one of peugeot`s machines to do A DIAGNOSTICS test on the car.
    Dec 2004
    dorset uk
    7
    Quote Originally Posted by Zbiku205gti
    but on all the pictures i can find of the engine bay it has an airflow meter fitted and ever on ei have asked say's it should have one!so could this not be where the airflow meter plugs in!?
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Hi,
    The car would not run without some way of determining air flow & I assume it does somehow, either by an air flow meter or map (manifold pressure) sensor. Has it had an aftermarket engine managment system fitted? These usually run a map sensor & could be all set up wrong (to pass the mot test anyway ).
    Will
    Fellow Frogger! J4RS's Avatar
    178
    Hi chief....
    your missing airflowmeter is part of the missing airbox......
    I would convert to MAP sensor.... to correct the mixture... plus you will get more power..... if you want more info on this let me know...
    P.s ,,frogger's you can do this on 205GTi's too...
    Lee.
    "The anti-christ has been with us for a long time, he mean's business..... BIG business"
    Dec 2004
    dorset uk
    7
    Quote Originally Posted by J4RS
    Hi chief....
    Lee.
    yeah id like some info on this mate! this is possably what has been done if u look next to the battery there is a co2 adjuster screw mounted to a plate would this have something to do with a map sensor mod?!
    Fellow Frogger! DRD180's Avatar
    Thasala Thailand, Alexandria NSW
    296
    I dont know about the airflow meter but just wanted to say that you have a very nice looking ride, great colour.
    6,498
    Quote Originally Posted by WAUTY205
    They run with the AFM unplugged. Don't ask how I know.
    2003 PEUGEOT 206 GTi
    Dec 2004
    dorset uk
    7
    i had another look today and i i think the airflow meter has been replaced by the littlebox on the alu panel screwed to the part next to the battery could i just unplug this and plug it back to an airflow meter!?if anyone can just tell me the quickest easyest way to get the emmisions down so it will pass the test id be most greatful!
    Perth Western Australia
    2,694
    Default Urgent help,airflow meter?
    Could it be a faulty air temp, coolant temp sender* or coolant thermostat?
    The CO reading of 11% is high even if these are faulty. Could your pod air filter be clogged or damp?
    The square silver fitting between the air filter and manifold, could this be an air flow sensor. There is no map or air flow meter visible in the pics.
    One of the reasons I bailed out of the trade was because of the constant changes in efi systems. This old brain could only grasp so much!
    Interesting colour, I bet that sat in the showroom for an age?
    *This should read, "coolant temp sensor" for the injection system.
    Oct 2000
    Auckland, New Zealand
    533
    Just on a different note, I presume this is a Ryton assembled 405? My 405 has a MOTA sticker on the passenger-side strut top, whereas this has a MOMH sticker.
    I'm curious as to what these stickers refer to?
    178
    Quote Originally Posted by Louis
    Paint code???? seem's to match my book??? good question! anyone??
    Sep 2003
    North Parramatta
    3,997
    I was going to second the paint code, Lee, but I've changed my mind
    I'm guessing it's the trim code. Paint codes tend to have numbers in them.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
