GTi-6 In MOTOR
Results 1 to 25 of 44
Thread: GTi-6 In MOTOR
    64
    GTi-6 In MOTOR
    Well the current MOTOR mag did a review of the GTi6 in it's past blast section, though it seemed very general and focused of the S16 and base spec models as well. Interesting fact was that they said the brake wear on all pugs was high and rotors were constantly getting warped and needed machining. I know my dad's old 405 had the discs machined a couple of times (the passenger could even feel the shudder a few times), but I would have thought that has more to do with the way the car is driven (usually pretty hard, especially on brakes) than a defiency.
    But it was good in they said if you don't have the $$$ for a GTi6 then an XR with low profiles and a free-flowing 'Zhaust is a good option.
    Peugeot...
    ...The True Lion
    NSW
    1,063
    It didn't really say a lot about them. It was all fluffy stuff without any real information being given.
    Definately wasn't going to cause a frenzy of buyers for them, thats for sure.
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I was at Auto France at Artarmon a couple of weeks ago. They said business is slow but the sale of 306 rotors and pads is keeping them going.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    2000+ Brad's Avatar
    2,404
    Hmm, the EBC pads, although brilliant seem to warp my rotors with 5000kms
    Not very noticable though. Will only happen occasionally, and thats always above 100km/h
    490
    I pretty sure that macquered on these forums went through 3 sets of rotors in 15,000kms.
    Cary, NC USA
    67
    I think rotor warpage has a lot to do with how the car is driven, and how well new pads are broken-in. If you have gotten the rotors hot and you hold the brake at a long stoplight, the rotors can warp. Parking and using the handbrake can cause rear rotor warpage if they're hot enough. Improper wheel nut torque can also cause warpage.
    I have heard that EBC pads can be a little harsh on a set of rotors. I've been using Mintex pads on our 505s with great success. As long as the pads are broken-in carefully, the rotors seem to hold up quite well. I think the Mintex pads give a nice soft but progressive feel, with a little more resistance to fade. They don't last very long and they create a good bit of dust. I believe this dusting helps shed away some heat and that's why fade resistance seems higher.
    I have seen the front and rear rotors glowing orange with sparks flying out from behind the wheel spokes on one of our 505s, but everything was fine afterwards. This was an all-out ABS stop from over 130 MPH late at night. I was in awe--it was actually pretty, in a way.
    -Joe G.
    Bedworth, Warwickshire, UK
    31
    There has been a huge debate over here about the best pad / disc set up on Peugeot's.
    It has been generally agreed that the best set up is to leave the rear disc's & pad's as standard & to use Mintex 1144 or Ferodo DS2000 pad's on standard disc's at the front.
    EBC pad's, whilst good on bike's, have been known to eat disc's very quickly. The Greenstuff pad's are known to bite sharply & unpredictably when cold & if used heavily when warm, will wear very quickly.
    Hope this helps!
    106GTI - Road Legal Go-Kart!
    Fellow Frogger! Mi16 Man's Avatar
    Canberra, ACT
    711
    Quote from a most reputable non-dealer Peugeot workshop on Sydney's Northern Beaches;
    "If you pull up and park, then a dog pees on your wheel, that will warp discs just as bad as good hard stop!"
    Good idea not to wash your car straight away after you have driven. Can pose a problem when hanging around in a car wash bay @ Carlovers tho'!
    So if there is any un-even cooling or heating on the surface, that creates a problem. But, as mentioned by XN6 guy, after a good hard stop, take your foot off the pedal and apply the handbrake. This ensures that the pads are not holding heat in the immediate area and give the whole disc a chance to cool down at the same rate.
    Also, when bedding in new pads, have been advised not to hit them hard within the first 100kms or so. Sure, to avoid an accident, no problem but within good reason.
    Keep those dogs away from our cars!!!!!!
    Stu G
    "Take a Lion through a corner - FAST"
    Current Fleet;
    2010 308 XSE HDi SW [Vapour Grey]
    2010 VW GOLF GTI [Carbon Steel Grey]
    In the Family;
    2012 508 Allure HDi [Thorium Grey]
    2008 207 HDi XT [Bianca White]
    Past "Frogs"
    2008 308 XSE HDi SW / 2006 307 XSE HDi Touring / 2001 306 XSi / 2005 206 GTi180 / 2005 407 HDi / 2003 206 XT / 1993 SII 405 Mi16 / 1990 205 GTi / 2x 1985 505 GTi S1 / 1976 504 / 1982 20 TS / 1997 306 XR / 1992 205 Si
    con
    con is offline
    sydney, nsw, australia
    521
    folks,
    the reason your 306 disks are warping is that the monkey on the air wrench is not tightening the bolts evenly; and this is straight from the manufacturer (DBA).
    con... 306xt
    (two sets of rotors replaced under warranty) and none since finding the cause (...wonder if I can borrow that dog from the northern beaches)?
    south australia
    225
    hi guys,cons right since doing a bit of research i went out and bought a warren and brown rattle stick,this stops you overtightening the nuts.(the cars}i havnt had a set buckle yet.the water theory is good too,i had a cortina gt 500 wich was a bathurst production car it had huge air scoops on the front for the brakes,in winter after a fast run the water would get scooped up and spray the discs,presto buckled discs.also sitting at the lights after a hard use gets localised hot spots through the pads in one spot.this can do it if your discs are a bit thin.
    ACT
    16
    This an e-mail from me to EBC Australia with reply
    Hi,
    I have a set of EBC Green Stuff Pads and EBC rotors on a Peugeot 306 GTI6. This combination has worked well. Good bite and stopping.
    The pads and rotor have been on for a about 12,000 KM of normal street driving. The rotors have developed heat spots , heat cracks and have
    become warpped.
    I return them to ACT brakes. Who stated that the brakes had been misused or a fault with car (no fault noted). They machined the brakes for ~$90.
    I am not happy that after 12,000 "performance" rotors should not becomming warpped and costing me money. I belive that the EBC rotors are not providing the service that they were designed for.
    Is this normal for EBC rotors ? Should ACT brakes have returned the rotors to you for replacement?
    Reply
    Dear Mr Brown
    We have never seen a rotor warped yet that wasn't used for motoracing.
    Yours would not be warped, you would have I suspect have "brake shudder".
    The spots are not heat spots, they are low and high spots, caused by uneven contact of the pad with the rotor surface.
    Any rotor manufacturer will give you list of the problems causing this,
    PLEASE don't automatically blame the brake pad.
    The first thing that needs to be checked and not uncommon is the rotor ateral run out which will cause uneven wear then brake shudder (known as DTV disc thickness variation).
    The second most common cause noted by local rotor manufacturer DBA is OVER TIGHTENING of the wheel nuts with a rattle gun putting distortion in to the rotor.
    Interestingly the Goodyear Tyre shop next door has had the same problem on a 306 3 times until the hub run out was checked.
    A flat pad on a flat surface CAN NOT cause the scalloped out low and high spots you have.
    The problem needs to be analysed and the cause found, eg; have you had the wheels removed and re fitted for any reason.
    Cary, NC USA
    67
    [quote]Yours would not be warped, you would have I suspect have "brake shudder".
    The spots are not heat spots, they are low and high spots, caused by uneven contact of the pad with the rotor surface. <hr></blockquote>
    Ummmm, this "low and high spot" thing sounds like a warped rotor to me... Am I missing something?
    -Joe G.
    1000+ Posts brenno's Avatar
    1,937
    How tight are the wheelnuts supposed to be?
    And why is it that you can affect the brake rotors due to this so call overtightening when a pleb like me should me able to take the wheel off as many times as needed.
    Seems stupid.
    Cary, NC USA
    67
    Uneven or excessive wheel nut torque can put stress on the hub and therefore the rotor, causing warpage.
    Ever notice how the factory supplied jack handles only allow a seemingly small amount of leverage. Most of the time, the length of the handle is determined in part by how much torque an average person could apply when attempting to tighten the wheel nuts, thus preventing any possible overtorque situation when changing a flat.
    As a general rule, never use an air impact gun to install the nuts. For accuracy, use a click-type torque wrench and set it to the factory wheel torque specification.
    -Joe G.
    6,533
    Joe, I think they probably meant thinner and thicker parts of the disc, whereas a warp is really the disc the same thickness all around, but with 'bends' in it.
    I've read many a time that unevenly torqued wheel nuts, combined with heat cycling, can warp discs. I just accept that it's true, as it comes from manufacturers of discs. Another point is that you shouldn't use anti-sieze grease on your wheel nuts as the torque setting doesn't read properly.
    On saying that, I don't use a torque wrench (even though I've got two) AND I put copper grease on the studs. I think if you're pretty good at judging even torque settings by hand it's enough. As a rule I also always loosen and retighten wheelnuts if any other person has has to touch them. And my nuts are just pinched up, no more.
    Stuey
    2003 PEUGEOT 206 GTi
    11,007
    What an interesting set of comments!
    My limited experience here is a 1995 306 XT that we've owned from new. 97,000 km, one set of pads so far.
    It'll get new rotors next service because of wear. Brakes feel perfect and always have.
    I also drive a 1964 Renault R8. 300,000 km and original rotors. No warping, no shudder. Heaven knows how many sets of pads since we bought it in 1973.
    I avoid airgun tightening of course. As you would!
    What are these guys doing to their brakes???
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    490
    Muhahahaha!
    /me goes for drive and tortures brakes again..
    74
    All this seems to make sense, but how do you avoid having an impact gun used on your wheels if you take your car in to have the tyres replaced? Does the over-tightening/un-even tightening have an immediate effect on the rotors or is it driving the car for a certain distance after this has happened? ie. if a mechanic has used an impact gun on my wheels, can rotor warpage be avoided if the wheel nuts are loosened and re-tightened to the correct torque setting the very next day?
    6,533
    Yeah, should be OK - just don't flog it and really heat up the discs until you've retorqued the nuts.
    Apr 2002
    Tangalooma
    160
    Incorrect torque on wheel nuts can also cause cracking and/or distortion of some mag wheels. Torque figures quoted for 405 is 85Nm (63 lbf ft) this should be fairly standard for most cars. In short a torque wrench should be used to tighten road wheels. wink
    Quality is remembered long after the price is forgotten!
    12,269
    the last 2 tyre places i have been to with my car have both used a normal wheel brace to nip up the wheel nuts on my car and to remove them
    it has been a few years since i have seen a tyre place use a rattler on alloy wheels
    i have only ever seen them use the rattler on steel wheels over the last 4-5 years
    but with all the km's travelled over the years and some pretty hard driving when i used to live on the highlands going up and down the pass all the time i have never had a disc warp
    on my 306 i wash the black dust off the wheels and check the front brakes all the time and the only thing i see wearing are the pads
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Gordon, NSW
    4,527
    I recently had the rear pads replaced on my 306 GTI and was told the discs are too thin to machine, have any of you had the same problem? Appears some of you have machined your discs, but my tyre shop (who I've used for a long time) suggested that this wouldn't be a good idea, as there simply wasn't enough disc to machine.
    Also, does anyone know what the torque setting is for the 306 GTI?
    Lincoln
    - Lincoln
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    Lincoln,
    I've had my GTi6 front discs machined twice (who, me? evil ) so far and at my 50,000km service record there's a note saying that the discs may need to be replaced in the near future as they are starting to get thin.
    Your discs with 60,000km of normal wear might be approaching the thickness limit.
    The discs do wear down with use (if you feel the edge of the disc with your finger, you should be able to sense a little 'ridge' where the pad has started to wear the disc down); machining them obviously takes more thickness out of them. I guess that a thinner disc is no good, as it wouldn't be able to handle heat under braking as well, and might make it liable to crack ?
    I have no idea what the torque specs are for the wheel, BTW.
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    490
    I found the EBC greenstuff pads worked well, however in a short period of time the discs are completely cactus (the warp is so major I do not think it could ever be rectified!).
    Will be getting some slotted numbers soon.
    Gordon, NSW
    4,527
    Thanks Rek, mine has done about 37000kms (I changed them at 30000), and they were the first brakes (I believe) for the rears...how long did your rears last? Perhaps the first owner had already machined them once, and that shop did them badly...
    Thanks, Lincoln
    - Lincoln
