remote central locking
Results 1 to 8 of 8
    Dec 2004
    LONDON/ UNITED KINGDOM
    9
    Icon5 remote central locking
    hello,
    in the 205 1.9 gti there is a sensor by the map reading light, how do you remove this central unit as there is a frequency on the underside of the sensor unit which can be sent to peugeot to obtain a remote key for the central locking system. this should stop the key scratching the door @ night.
    Cub
    Cub is offline
    Member Cub's Avatar
    SYDNEY
    82
    ...I've got a similar question but rather my remote control doesnt seem to work properly. It has new batteries but doesnt help.
    Anyone know of a common problems that I might be able to look at and restore the "blip, blip" to my "beep, beep"
    CUB
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,751
    a new remote, coded to your car, from Peugeot is silly money. Go to Jaycar, buy a remote control for central locking for $70 and wire it in. Very easy to do, and its better than the Pug one anyway, cause it is radio, not infra red (ie it will work form further away and in your pocket rather than requiring line of site with the pick up)
    CitroŽn Tragic UFO's Avatar
    9,738
    Quote Originally Posted by Cub
    The plip for my XM was a non worker for the whole 3 years I have owned the car, until....
    At a recent tech day, one of the ccc of nsw members who is clever with a soldering iron, reheated all the joints on the plip circuit board to eradicate dry soldered joints. It has worked perfectly ever since.
    You will need a fine soldering iron and an illuminated magnifying glass. Took this person about 30 minutes to do the job. I will not reveal his name as he may be bombarded with requests.
    May 2002
    canberra...
    8,751
    Quote Originally Posted by UFO
    Hmmm sounds like its worth a shot with the R25 PLIP, which worked fine up until recently. Sender seems okay, with new batteries and lights up its little red light and all, but no locking. Might have to try a little soldering work on the pick up module....
    Cub
    Cub is offline
    Member Cub's Avatar
    SYDNEY
    82
    Quote Originally Posted by Haakon
    Has anyone done this to a 205 s2 before? Just after some advice before I start messing with Electricals
    CUB
    9,738
    Note that with my plip the light would flash briefly like it was working, whereas normal operation is a long light. When you consider what happens with the plip it gets a lot of knocking about and twisting (esp as you turn the key in the ignition) and wears out the board.
    The pickup in the car is usually not the fault. (which is just as well because a replacement is in the $400 vicinity)
    Dec 2004
    9
    Default frequencies
    if the frequency is known a new key can be tuned to work for £50 fr peugeot, or once you know the frequency i`m sure there are others who will do it 4 a lot less. the frequency can be found on the inside of the sensor by the interior light. but how do u remove the unit?
