Driving in extreme heat in NSW the other day.
Results 1 to 25 of 49
    Fellow Frogger! codgamer's Avatar
    Jul 2004
    HK
    160
    Default Driving in extreme heat in NSW the other day.
    Hi guys,
    I was driving my 180 in Sydney on Wednesday. The thermostat at the trip meter said 47 degrees. The coolant was at 100. But the most worrying thing was the fan was extra noisy. But the extra noise comes and goes during the trip. Is that normal? Is if just the fan working harder because of the heat? Can anyone shed some light on this. Thanks
    Codgamer.
    Jul 2004
    nth balwyn, victoria
    1,428
    im not familiar with your model but check to see if a second fan comes in on a thermostat at a certain temp,this could explain the coming and going noise and the fan stopping when the car goes below said temp and coming on when above-BAZZ
    Fellow Frogger! 30780Y's Avatar
    Jun 2004
    Sydney/ Australia
    250
    My 307 is so noisy too......with the fan working overtime
    Also the heat made my remote locking to fail too.........
    Mine temp gauge said 48c that day and not 47c
    Gordon, NSW
    4,527
    Sounds like the 2nd fan kicking in. I'd get it checked out at your next service, just to ensure the fan is nicely balanced.
    9,223
    Fans make noise because they're spinning in the air... you won't change that... balance won't make any difference, and I doubt that anyone would do anything other than laugh at you if you went into a dealer and asked them to ensure your fan's balanced!
    No, I take that back. They wouldn't laugh... they'd rub their hands together, write 'checked fan balance' on the bill and charge you for doing nothing...
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    From someone who lives in a place where it gets real warm. Yes the fans can be noisy, but you only noice it when you stop and they kick in. Standing at the door the heat wafts from under the car. When moving again the fan stops, they have to run fast to get the same sort of level of cooling driving the car provides.
    - XTC -
    Now this is a .sig
    Gordon, NSW
    4,527
    Haha. Well when a car is under warranty... you'd probably end up with a new fan at no cost!
    12,256
    i have one that is out of balance and i hear it a lot more now when it cuts in than before when it was balanced
    i'll get around to fixing it again one day
    might go for the later model fans and get away from the single screw arrangement they have
    1 x '98 306 GTi6
    9,223
    How do you know it's out of balance?
    Truly, if it was, it would stuff the bearings in the electric motor in very short order...
    12,256
    because it has bent the shaft on the motor that drives it and yes the bearings in it are on their way out
    and i know it is out of balance as there is a small piece missing on the outer edge of it from when the screw let go and it spun off and got damaged in the process
    1 x '98 306 GTi6
    9,223
    So this is a problem, not like the one described above... merely thinking that fan noise indicates balance issues...
    I lost a fan blade once and the car shook like the engine was falling out of it. Mind you, I was doing about 135kmh... but I was really relieved the engine didn't have a serious fault... established by looking forward and seeing the fan blade poking up through the bonnet!
    1000+ Posts brenno's Avatar
    1,937
    Quote Originally Posted by 30780Y
    I can beat that
    Jun 2004
    Sydney, Australia
    40
    Yeh, on my 138 the fan is pretty noisy when its a 40 degree day. Can only hear it when the car is stationary as already mentioned.
    12,256
    Quote Originally Posted by macquered
    I can beat that
    i'll remember to take a pic of mine on the next hot day here
    i am sure i can beat that one
    1 x '98 306 GTi6
    Fellow Frogger! blu180's Avatar
    May 2004
    mosman
    238
    Quote Originally Posted by codgamer
    Hi guys,
    Codgamer.
    I can't hear my fan, the engine's too noisy... But my temp was up around 100 deg, at one stage it even rose up a tad higher for a minute or two. I'd say my fan kicked in cause it dropped quickly.
    Jul 2004
    HK
    160
    So I take it that it is just the second fan kicking in and it is normal. Since I had my car in April, it has never been this hot, not even during my driving trip to Alice Springs. So my second fan hasn't worked since April, talk about a cushy job!
    Codgamer.
    9,223
    Absolutely normal...
    And a trip to Alice would be easier than driving up the streets of Parramatta... because you have some speed up to force air through the radiator.
    XTC
    XTC is offline
    Mar 2003
    8,566
    So I take it that it is just the second fan kicking in and it is normal. Since I had my car in April, it has never been this hot, not even during my driving trip to Alice Springs. So my second fan hasn't worked since April, talk about a cushy job! Codgamer.
    Amazing the cooling at 200KPH
    - XTC -
    Now this is a .sig
    Fellow Frogger! tasgill's Avatar
    Toowoomba
    290
    Thanks for that Ray, I too thought that slightly out of balance fans caused extra noise, not caused by changes to the air movement but by the imbalance causing resonation in the body panels, etc.
    Terry
    Member GTI145's Avatar
    Jun 2004
    54
    206'S ONLY HAVE 1 FAN......and fan noise is normal on very hot days,well my does.....
    Last saturday it was over 40 deg here in Sydney.
    At Curl Curl beach had my 180 parked in the sun...got in and the display said
    62deg outside......temp sensors on the mirrors had been in the sun for tooo long
    Should have taken a photo....
    '89 405 MI16
    '00 206 GTI
    '04 206 GTI 180
    Fellow Frogger! jfn180's Avatar
    725
    my 206 had 50degs on it at 3pm when i finish work
    97`black 306 style sold JFN 306
    04 Black 206 GTI 180 JFN 180 FOR SALE
    I HATE V8 LANDCRUISERS
    WEST TIGERS= PREMIERS 05
    9,223
    Oh, they might well do...
    But the sound of the fan is loud enough to cause concern.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Putting this all into perspective for you, the average hot water system is set to deliver water at 55 - 60 degrees.
    How's that make you feel?
    Alan S
    6,416
    Quote Originally Posted by GTI145
    206'S ONLY HAVE 1 FAN......and fan noise is normal on very hot days,well my does.....Cheers
    Is it a two speed fan? Might explain why there are different levels of noise...
    2003 PEUGEOT 206 GTi
    Jul 2004
    HK
    160
    I wonder at what heat will the external temp sensors malfunction?
    Codgamer.
