Key problem
Results 1 to 9 of 9
Thread: Key problem
    Fellow Frogger! 30780Y's Avatar
    Jun 2004
    Sydney/ Australia
    250
    Default Key problem
    Hi all
    Had a little problem with my key today......
    I left the car under the sun for 3 hrs today and when i got bk to my car, i couldnt open the door with the remote control on my keys..........
    1st thought was a flat battery on the key, so i just open the door the old fashion way.........
    Once i got in the car it was very very very HOT.......
    When i got home tried the keys again but failed........
    However i tried it out tonight and it worked again...........
    So weird!!!
    Anyone got similar problem??? Any1 know the problem???
    Key is stuffed or the battery is nearly out???
    Lucky i am due to go to the service dept next monday to get the X5G upgrade on my car........so hopefully they could help me solve the problems too......
    THNX in advance
    12,266
    shouldn't be a battery unless it's a dud one
    i still have the original in my 306 and it's pushing 7 years of age
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! Industrie's Avatar
    Brisbane Australia
    635
    yeah, but the 306 uses infra red, while the 307 uses acoustic so may use more power. Although I'd still think that it's a short life for a battery
    Jun 2004
    Sydney/ Australia
    250
    Is it due to the heat????
    Cos when i got in it was very very HOT.......
    What should i do now????
    12,266
    give the service manager a call in the morning and stay on the phone till he gives you an answer
    it could have been the heat
    i leave my windows down in the car about 5-10mm but that might be hard to do where you are
    1 x 2018 3008
    Jan 2003
    Nambucca Heads - NSW
    19
    It must be the heat. I got back to my 505 GTI this afternoon and the central locking refused to work. The car wasn't in the sun, but we had 40 + degrees here today and the car was parked nearby to a hot air outlet for a building's air con. Am hoping it will work again when it cools down!!!!
    I guess if it works fine when cooler, then it has something to do with the heat.
    Ian
    Member jchan's Avatar
    May 2004
    Springvale, Melbourne
    57
    Icon3
    I will say just the heat. Which may be the heat make ur central locking motor over heat before u actually push ur remote to use it. It happen on my Laner before, when the temperature go over 35C then the central locking will not work. Hope it helps!!
    Jacky
    1995 Peugeot 306 XT 1.8 MT
    Performance:
    JAMEX Lower Springs, Griffiths Eng. Quick Shift, K&N Element Replacement Filter, 2 1/4" Catback Custom Make Exhaust with 2 X 3" DTM Style Twin Pipes Outlet, BF g-force 185/65/14
    Sound System:
    Sony CDX-F5700, Hertz 4" Split, JBL 6" 2 Way, Alpine MPR-M200, SoundStream EGW-10 10" Sub
    Outlook:
    BOSCH Silver Evolution bulbs, Aero Wipers, Momo SliverJet, RAZO Gear Knob, RAZO Carbon Paddle, Sparco Pro 2000
    Brisbane Australia
    635
    It might also be a problem with the software. My car wouldn't lock once because it though the key was still in the ignition. Whenever i opened the door a chime would come on. It fixed itself after about half an hour.
    Jun 2004
    Sydney/ Australia
    250
    Thnx all for the help
    I'll give the service manager a call tomor anyway
    but from what u guys are telling me, it failed today is becasue of the Hot Sydney weather ......
    Keep u guys posted
    CHeers
