505 s/w reverse lights
    Jun 2004
    14
    Default 505 s/w reverse lights
    Does anyone have a solution to the problem of reverse lights not working on 505 autos. Mine is an 85 SR wagon, and I don't know whether it applies to sedans as well.
    So far, expert advice is that the switch or housing wears and even a new switch does not fix it. Adjusting the seating of the switch with bushes can get starting or reverse lights, but not both.
    Any ideas?
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Start by testing the switch.
    Use a suitable lever to see if extra travel will restore the lights.
    If switch OK, work back to globes, (or first start with the globes).
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Jun 2004
    14
    Globes OK, powers OK, switch OK, even brand new switch won't turn on reverse lights.
    Picton NSW
    1,412
    Check wiring continuity????
    Remove switch and manually move to on position while connected. (Ign on in PK).
    If the selector is worn, then the fix is difficult. Start replacing worn bits.
    2003 T5 307 HDI
    2013 LandRover90
    Wodonga
    928
    Icon7
    Mine does the same thing, no lights in reverse. It also won't start sometimes. I find by getting under the left hand side of the car and belting the switch with four wires coming out of it on the gearbox solves both problems. It must be a combo reverse lights/don't start in gear switch. You can adjust the linkages into the box to fix the problem properly I've been told. I plan to fix mine by fitting a BA7/5.
    Matt.
    Jun 2004
    14
    What size hammer?
