205 GTI Drivers Seat - advice Needed
    Member ozclio's Avatar
    Aug 2003
    57
    Default 205 GTI Drivers Seat - advice Needed
    Hi all, I have a 1989 205 GTI with a sunroof. Problem is that my head pokes up against the head lining. Its quite annoying and no matter how I adjust the seat i just can't seem to get a comfortable driving position. If I move the base of the seat forward my knees get jammed up. If I recline the backrest I'm too far away from the steering wheel which makes it difficult to steer with no power steering. I have been told that i may have the following options-
    Remove some padding on the seat base to lower the driving position.
    Redesign the mounting frames under the seat, although I have now decided against this option.
    Buy a velo race seat or similar.
    Its unfortunately looking like I will have to buy a new seat. Has anyone else experienced this problem? any recommendations,
    Trent.
    Fellow Frogger! Industrie's Avatar
    Brisbane Australia
    635
    Welcome to the world of French motoring. Ergonomics, what are they?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    I had the same problem. I think i ended up removing some of the lining of the sunroof. Just adjusting it by cutting it and folding it up. From momery you can cut it with a stanly knife and fold it up. You can still make it look like its original if your careful.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Don't the seats have plastic spacers?
    At least I think mine did. I left them out when I put the seats back in a while ago now.
    Maybe they were not factory?
    They lifted the seats by about 15mm from what I can remember.
    Will
    May 2002
    642
    There are some thick plastic spacers under the seat frame, well there is on mine, try removing those and see if you have enough space. You will need a torx headed screwdriver to undo the bolts.
    05' Megane 225 Cup
    Aug 2003
    57
    Thanks chaps perhaps I will do a combination of all for best results.
    Much appreciated.
