205 Engine Mounts
    Sep 2004
    Fitzroy VIC
    26
    Default 205 Engine Mounts
    Hi y'all,
    The hits keep on coming :-)
    Mechanic who fixed the clutch cable (see separate thread) reckons my engine mounts are buggered. Assuming they are (he adjusted the clutch incorrectly and told me 'that's how they are'...what, I can't get reverse cos that's how they are...?)
    Anyway, assuming he's right, has anyone had this done recently? Just wondering how much it is to do. I have several thumbs and no brains, so I won't be doing it.
    z.
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    G'Day,
    If it is the top mount (drivers side), they are $70 from memory, and about 30 min labour.
    If it's the bottom mount, then that is a barstard. New mount and bracket from memory was $300 from Pug Aust. You can just get the mount part, but pressing the old one out (for me) took 3 hrs for a machanic friend to do...
    the other pain in the butt is you have to remove the drive shaft to change that mount. That in itself is time consuming.
    I've heard a rumor that there is a 'trick' in changing the rubber part whilst the bracket remains on the car.. but its a rumor
    Justin
    Quote Originally Posted by zerogeewhiz
    Hi y'all,
    z.
    Pugsley The 1987 205 GTi Peugeot
    Jul 2004
    nth balwyn, victoria
    1,428
    the top mount rh side is- $38.14-peugeot
    lwr bush,tansmission mount-$19.58-euro auto imp
    bottom mount-$19.14-pug
    if you do the top mount make sure you get the rubber limiters each side of mount-$17
    usually about 30mins-1 hr for each install-BAZZ
    Sep 2004
    Fitzroy VIC
    26
    Thanks guys. I am the worst mechanic on the planet, so I will be getting someone qualified. :-D
    z.
