Non-interchangeable wheels
Results 1 to 8 of 8
    9,223
    This is unbelievable, so I have to ask if anyone around here has any idea if it's true or not.
    On the Peugeot-L forum it's reported that mag wheels on the 85 and later 505 wagons don't interchange rear to front. The front wheels will fit on the back, but not vice versa.
    The wheels mentioned are 14", I think they said the 15" wheels did fit both ends.
    Anyone ever heard of this?
    Cary, NC USA
    67
    I've seen what you're talking about, and honestly I have never heard of this.
    I know there are 2 versions of that 14" alloy... a 5.5J and a 6J, but that's the only difference I know of. The offset is probably (more than likely, actually) the same. Maybe the wider wheel won't clear something on the wagon... who knows...
    -Joe
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I think this might be due to the extra negative camber built into the stub axle on those cars. This may cause some of the 14" wheels to touch the strut.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    9,223
    But they presumably carry only one spare?
    So are they to have odd wheels on the rear if they get a flat tyre?
    con
    con is offline
    sydney, nsw, australia
    521
    Could it have something to do with ABS brakes (sensors or .....?
    con....
    Sydney NSW Australia
    137
    Sounds like an old wives tale to me.. what's more it doesn't make sense.
    I had an 89 505 GTI Series II wagon for a number of years. It was fitted with 14" mag wheels all round, including the spare. The wheels were all the same.
    Denis
    6,527
    Not familiar with the 505 wheels/hubs, but have they got hubcentric wheels with different sized central holes? That is, wheels that interference fit on a central boss on the hub. Seems crazy.
    Stu
    2003 PEUGEOT 206 GTi
    Nov 2001
    1,640
    I suspect Dave is on the right track, with his mention of the struts. I once spent a harrowing day 're-shodding" my old SLi wagon (with steel wheels). Being adventurous /foolhardy I tried some Pirelli tyres instead of the standard 185/80 Michelin reinforced. They hit the struts, despite being same profile, same load capacity etc. The same applied with some Bridgestones as well. The tyre boys were very happy to see me go in the end!
    I wonder, in this case, whether the people posting Peugeot-L actually had different tyres fitted on the rear rims. Sounds more likely than variable rim sizes. (Only Citroen do things like that!)
    Rod
    Rod's Home Page
    Rod's car page
