Diy 205 Td?
Results 1 to 17 of 17
Thread: Diy 205 Td?
    Adelaide, SA
    29
    Default Diy 205 Td?
    Hi!
    New to the world of Peugeot. Currently I have an unfinished Subaru in the shed and catch the bus. I'm interested in moving to a car that can run on biodiesel, and ideally it would be something with a bit of get-up-and-go (possibly to do some amateur rallying). Call it "sustainable head-turning". I've read awesome reviews of the turbo-diesel 205 (performance and economy), but I understand they weren't released in Australia.
    Wondering if anyone has any idea whether it's possible to convert a petrol 205 to diesel, say by using a 405 SRDT engine/gearbox. If it's possible, is it likely to be prohibitively expensive?
    7,487
    It should drop straight in. All those models have the same engine mounts. You'll need to use late model, 90kW GTi driveshafts.
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    Quote Originally Posted by Jimmy Ward
    Hi!
    i know the rough location of posibly the only diesel 205 in australia. There was one which is a personal import and a guy in brisbane owns it, not sure that its a turbo though. Aparently the 205 turbo diesel engine was a bit of a pig from the loose information i've heard though. You might want to consider a 405 SRDT or something like that (if space permits)
    Fellow Frogger! PUG309's Avatar
    Feb 2001
    Sydney, Australia
    231
    Would you need to change any of the fuel line components, such as fuel tank???
    Daniel Djuracic
    Ex UK spec 89 309
    206 XT 1.6 16V (Diablo Red)with Peugeot Lion in back windows
    Sunshine Coast
    4,520
    Quote Originally Posted by PUG309
    not sure on that, the one i was talking about was an actual import from the UK i beleive and was sold originally as a diesel (no modfications). i would asume though that you wouldn't want to mix petrol with diesel so you would at least want to clean the tank out fairly well
    Jun 2004
    401
    you can get the tank acid cleaned for about $60.
    i actually posed this question about a week and a half ago. i was looking at basically putting the front of a 405 SRTD (mechanicals) in a little 205. i reckon it would be an incredibly economical car with loads of torque and power to burn.
    i you go ahead with this i would love to see some photos and hear some feedback.
    Aug 2002
    1,290
    Sounds like that could be an interesting project for the 405srdt gearbox, driveshafts struts etc that I have in the shed, not to mention the 405 diesel tank electrics, and even the dash.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    12,269
    Quote Originally Posted by 3006882
    don't do it
    you will have more troubles than it's worth
    just clean the tank out and then plumb it if needed and use it
    DO NOT ACID CLEAN
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jun 2004
    401
    what is the problem with acid cleaning tanks?
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,869
    Hey,
    It seems like quite an interesting idea!
    Could anyone tell me the specs of the 405 srdt motor?
    Can the engline be eaisily modified to kick out more power?
    How much would a 405 SRDT motor cost with low kays or a rebuild?
    Thanks heaps froggers!
    Cyas Stalled
    2005 Renault Clio 182 Cup
    Sunshine Coast
    4,520
    Quote Originally Posted by STALLED
    Hey,
    How much would a 405 SaRDT motor cost with low kays or a rebuild?
    Cyas Stalled
    ENGINE
    Engine code XUD9TE/L (D8A)
    Engine location Front
    Cylinders 4
    Valves per cylinder 2
    Head material Aluminium alloy
    Block material Cast-iron
    Bore (mm) 83.0
    Torque (Nm) 205
    Maximum torque 205Nm @ 2250rpm
    Power (kW) 69
    Maximum power 69kW @ 4000rpm
    Compression ratio 21.8:1
    Stroke (mm) 88.0
    Capacity (cm3) 1905
    Valve train SOHC
    Engine description Four cylinders, in-line, belt-driven SOHC, cast-iron, cross-flow alloy head, turbocharged with air to air intercooler.
    i'm sure more horse power could be gained from a welll designed front mount intercooler and runing more boost. As for the price of an SRDT engine ask a wreacker http://www.partslocator.com.au/ or you could pick up a complete donor SRDT with everything you need for about $6000
    the 306 XRDT is also similairly powerd, With 67 kW of power and 201 Nm of torque, and im sure you could find one fairly cheaply
    or there is always the 2.0 306 HDi if you could find one cheaply that delivers 67 kW with 211 Nm of torque at only 1900 rpm
    keep in mind i beleive that the XRDT, HDi and SRDT are cast iron blocks, which would probably affect the handeling
    you could probably have comparable power to a 1.6l 205 GTI which had 75 to 85kw, but you would have a lot more torque and a lot more power down low
    Adelaide, SA
    29
    Default Re: DIY 205 TD
    Thanks for the input! I'm getting excited...
    Does anyone know a mechanic who would have the know-how to take on a project like this?
    12,269
    every tank i have known to be acid cleaned has caused nothing but trouble clogging filters for months down the track
    for some reason once they are acid cleaned they keep on releasing junk when they are in use
    my experience tells me not to do it as i have never seen one be right afterwards and i have seen many a tank done
    1 x 2018 3008
    Jun 2004
    401
    pugrambo,
    thats really comforting to know now after i have had my tank acid cleaned.
    i expected to require regular filter changes for a while as there would be excessive gunk coming out of the tank, but i didn't expect it to last for that long.
    ahh well, mabey i will be the lucky one?
    bwaaaaaaaa hahahahahahahahahahahahaha
    better stock up on filters then.
    Member Certifiable's Avatar
    Sep 2004
    Queensland
    49
    (orestes) "i know the rough location of posibly the only diesel 205 in australia."
    Actually there are several 205 diesels in Brisbane. I bought mine thinking I'd be unique, but my mechanic shattered my illusions. He knows of at least four, and has at least two as clients.
    Brisbane's a funny place.
    Adelaide, SA
    29
    So does anyone have a rough idea of prices? Like, how much it would cost to buy a suitable 205, buy a 405 engine and do the swap (assuming all work would be outsourced).
    The 306 HDi sounds like a comparable option - what would you expect to pay for one of those? And would it compare to the 406 TD?
    Merry Christmas to you all, by the way!
    Sunshine Coast
    4,520
    you should be able to pick up an XRDT for a reasonable price if you can't find a HDi and you're not after the very last of the 306's... there is also a HDi in the vic trading post for $19,990
    MAKE/MODEL: Peugeot 306 HDI
    YEAR: 2001
    PRICE: $19,990.00
    BODY: sedan
    COLOUR: White
    TRANSMISSION: manual
    REGO NUMBER: QTB-582
    full electrics, sought after, super economical diesel, immaculateair con, airbags, pwr steer, service books.
    STATE: VIC
    SOURCE: Dealer Online Ads (Melbourne Trading Post)
    DEALER: Graham Birrell Motors
    DEALER ID: 4239
    PHONE: 0398903675
    ADDRESS: 99 Union Road
    Surrey Hills,VIC3127
