Stonefree,
I hope its the simple fix for your sake. If you want to try something that may or may not work. Try disconnecting the battery for a couple of minutes as a "master reset" for the climate computer.
If you get access to the elect connectors try giving them a spray with a WD40 type substance. (just a little). It might sound a little strange, but a few years back my 306 reverse lights didn't work. All the components worked, globes,wiring and switch. I studiously cleaned the switch connector on the gearbox with electrical cleaner several times with no joy. I asked an electrician where I work and he came out with some Maxsolve 200 spayed it connected it and it worked immediately.
That would have been the last thing I would spray into an elect conx. However I was proven wrong and it has worked successfully for me several times since. Globes, microphone connectors, XM engine management connectors etc.
Apparently the connection gets a waxy film or corrosion on them and electrical cleaner won't get it off but the Maxsolve makes the joint conductive again.
Goodluck and cheap fixes.
