Vibrate when braking
Results 1 to 25 of 29
    Fellow Frogger! 30780Y's Avatar
    Jun 2004
    Sydney/ Australia
    250
    Default Vibrate when braking
    Hi all
    I was driving on highway today and i found out a little problem with my 307
    I was driving 110Km and want to slow down so i brake
    but as i brake my steering wheel vibrate so much
    Any1 has similar problems???
    How to fix???
    392
    Get your wheel balance checked
    If not could be your brakes
    Jun 2004
    Sydney/ Australia
    250
    Quote Originally Posted by david206180
    had a similar problem recently where the car would vibrate badly at 110 and over. problem was a build up of clay inside the rim of one wheel from a quiet run of road. if it only when you put the breaks on, you should get them checked out at your dealer if you can as you calipers might have stuck out of alignment with the rotor.
    Thanks for that....... Im going in service this thursday anyway so get them check it out
    2000+ Brad's Avatar
    2,404
    If it's only under braking then the disks are warped and need machining or replacing.
    Sep 2003
    409
    it could be just cementide or non-uniform brake pad deposits on the rotor.
    May 2001
    Sydney, NSW, Australia
    3,635
    30780Y,
    Is your car an auto?
    My guess is that it is an auto - in automatics you do tend to brake alot more than in a manual. You also hold the brakes on hard when stopped in an auto, to stop the car moving forwards when in drive. Cconsequently the possibility of warping the front rotors is very much higher than in a manual, where you'd tend to either barely hold the brakes on, or put the hand brake on.
    My guess is the rotors will need to be machined and/or replaced to resolve it.
    Derek.
    Jun 2004
    Sydney/ Australia
    250
    30780Y,
    Derek.
    Thanks 4 that DEKA
    Yes is an bloody Semi auto car
    i will bring my car in to service this wk
    do u think will cost me money to fix it or will be cover by warrnety???
    the car has only done 11000km
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    unless the rotors are damaged its not a warrantly job unfortunately.
    Brake pads can leave deposits on the rotors in some circumstances as XsaraVTS mentioned. This will lead to a pulsating pedal at slow speed (light application will cause the brake pedal to move as you are rolling down the hill) and will feel like a shaking sensation at higher speeds.
    If you do a search for 306 brakes/pads there are already few opinions on it.
    May 2001
    3,635
    Quote Originally Posted by 30780Y
    Thanks 4 that DEKA
    Sorry, you're wrong. The 307 is NOT semi automatic. It has the Peugeot AL4 which is a true automatic gearbox with a hydraulic torque converter. It is "intelligent" in that it selects from a variety of predefined change-points and torque converter lock/unlock settings to give it better abilities and driving characteristics than many other automatics.
    A "semi automatic" would be a Citroen C3 Sensodrive, a Citroen C2 VTR, a Citroen C3 Pluriel or Peugeot's upcoming Peugeot 1007 which comes with the Sensodrive clutchless manual gearbox.
    It won't be covered under warranty... I don't think. If you've warped them in 11 000km, I think you might need to look at your driving style - it sounds like you brake *really* hard up to say a set of traffic lights, and then leave your foot jammed hard on the brake pedal. This means that the disc rotors are heated, and then cool at a different rate where the pad is held firmly against the rotor, causing the warping. Consider using the handbrake when at a standstill and/or brake hard on initial application, feathering your brake application to virtualy nothing as you stop. This has two benefits: it means your brakes don't get as hot (and get to cool down as you feather your braking pressure) and it stops your passengers heads from bobbing as you come to a standstill with the nose of the car in a downward attitude.
    Derek.
    Jun 2004
    Sydney/ Australia
    250
    Derek.
    ICIC so is similar to the A-Class???
    i think that is semi auto too with a cluchless gearbox
    Umm...... I don't brake hard
    Usually i put it on 2nd gear to slow down on the tiptronic
    Is it called Engine breaking (im not really sure what u call it in english)
    But i always wash my car when the brake may still be HOT
    and as i bucket water on the wheels
    i can c lot of steam sometimes
    WIll that be the problem???
    392
    ICIC
    Yes hot metal and cold water dont go well together hence the steam you see,
    Could be the factor why your rotors are warped
    Gordon, NSW
    4,527
    Nope, sorry wrong again. The A class is a clutchless manual. there's nothing automatic about this transmission...just the clutch.
    The auto box in the A class has tiptronic and that's just a regular auto with a tiptronic mechanism on it.
    May 2001
    3,635
    As GTI124 said, you were wrong again sorry.
    You've hit the nail on the head, and probably learnt the expensive way. Never wash a car just after driving it - you'll very easily warp the brake rotors. No different to taking a glass from the fridge or freezer and putting it under hot water really - things break/twist/crack when the temperature changes rapidly.
    Derek.
    Jun 2004
    Sydney/ Australia
    250
    Derek.
    O Sh*t!!! That must be the problem then...... Never do that again
    Thanks 4 that !!!
    How much will it cost me to fix it?
    DeKa u seems uknow quite a lot......... i'll ask u more in the future
    hope u don't mind.......haha
    Jun 2004
    Sydney/ Australia
    250
    Quote Originally Posted by GTI124
    O really
    i better not make any more suggestions!!!
    im always wrong
    Better do my research b4 i say anymore things
    Gordon, NSW
    4,527
    See what the dealer says, if they are warped, then check out what DBA (disc brakes australia) have for the 307, rather than taking the OEM rotors from Peugeot. You'll save a heap.
    Member NASSTY's Avatar
    Sep 2004
    75
    Driving through puddles can have the same effect especially on the L/S of a car cause the water usually travels to the gutter. Can't tell you how many times my rotors have warped on the l/s b/c of this.
    Sometime the vibration can be caused by split CV boots and consequently the CV's start to bind up. Especially noticable when breaking and turning at the same time.
    Fellow Frogger! Rusty@'s Avatar
    234
    I got new pair of front rotors for my 405 (cause they were getting tired) for $150 off our Pug club mechanic. Genuine Bendix, not that imitation crap that comes out of Taiwan!!
    Current: '06 Iron Grey 407 SV HDi '02 Silver Audi S4 '05 GTi 180
    Previous: '05 Aegean Blue GTi 180
    Previous: '04 Sahara Gold 206 GTi
    Previous: '95 Silver 405 SRDT (Fantastic Tourer)
    Member Griff180's Avatar
    Sep 2004
    Perth
    67
    Does the 307 have ABS ? This could also be the problem. When braking at high speeds the ABS kicks into overtime and sometimes makes the car shudder with it clamping and letting go of the rotors. My
    2004 Black 206 GTi 180
    Jun 2002
    1,516
    surely there wouldnt be a need for replacing the essentially new rotors (11,000kms). the amount of vibration that we are discussing is a 10/20um or 0.02millimeter. And there should be plenty of meat left to machine off.
    Jun 2004
    Sydney/ Australia
    250
    Quote Originally Posted by Griff180
    Yes 307 has ABS
    Gordon, NSW
    4,527
    Quote Originally Posted by tekkie
    ok. not sure on the thickness of the 307 rotor. the 306 wasn't the easiest thing to machine...
    May 2001
    3,635
    The 307 has the same brake rotors as the 206 GTi 180.
    Derek.
    Fellow Frogger! blu180's Avatar
    May 2004
    mosman
    238
    Hi all
    How to fix???
    I had a similar problem with my old 206 GTI. It turned out that the brake pads were glazing up. The cause of this was, I only ever used the brakes gently as I down shifted, rather than braking.
    Peugeot sanded them down with some wet'n'dry and all was good. I was told to use the brakes more solidly. The car was fine after that, I still braked gently, but gave the car a little 'trash' ever now an then so the brakes would be used well.
    Jun 2004
    Sydney/ Australia
    250
    Just got back my car from the SERVICE Dept..........
    They said my brakes are warped or something
    Changed new brake disc under warrenty
    But as i received my car
    One of the service guy there came to me and said
    My aftermarket RAZO pedal are too close together and he said as he drive my car
    he is touching the brakes and Accel pedal together
    so he said that might be the problem!!!
    Told me next time if it happens again, doubt will be under warrenty because of my RAZO pedals
    PS: Im quite happy with the job they did on it this time (for once)
    Also saw a blue 180 there
    that 180 just got BADGED by some1
    so he is waiting for his new BADGE i think
