That bloody ABS light again
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Icon10 That bloody ABS light again
    Hi guys,
    I was just wondering if someone else had this problem on their Mi16.
    When the car is cold or the outside temp is really cold and I move off without letting it warm up too much, the abs light comes on.
    If I turn the motor off the ECU resets and it goes away (usually).
    Is this just a bad earth, if so where should I look to fix it?
    I know the ABS play up on the series 1 but it seems to be working fine.
    cheers
    Dave
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Have you tried cleaning teh sensors and the serrated wheels.
    Alan S
    Glenroy
    1,141
    Icon10
    Alan S
    Sorry Alan inn the words of homer simpson "can you dumb it down a shay?"
    Where are the sensors/serrared wheels?
    cheers
    Dave
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    8,923
    David,
    If you take each wheel off and look at the back of the actual hubs, you'll find a serrated wheel. Mounted with just a mm or so of clearance is the sensor (easily found by following the co-ax that aattches to it) and the way the ABS works is that the sensor (a magnet) counts the number of serrations as they pass by it. When a wheel starts to lock up, the speed of the serrations passing the sensor slows down and that is when the ABS takes over and tries to keep them all going at the same speed.
    Given the location of the sensor and the serrated wheel, they attract a lot of dirt, grome and rust as well as any grease that may fly off a front wheel due to a busted CV boot and this will affect the operation.
    The sensors can be unbolted and cleaned and the serrated wheel cleaned up and often this is where the problems with these ABS systems stems from.
    This is what an ABS sensor looks like; in this I was greasing the sides where it is held in the mount. The face is the square end pointing towards you. That is what has to be cleanes and the wheel sits directly under it when it's mounted in the car.
    Hope that is some help.
    Alan S
    Glenroy
    1,141
    Icon10
    David,
    Alan S
    Thanks heaps for that Alan, I"ll get onto that on my next day off.
    cheers
    Dave
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
