How do I distinguish a square port head?
    Fellow Frogger! zac505's Avatar
    Coffs Harbour, NSW, Australia
    226
    Default How do I distinguish a square port head?
    Just wondering how a novice like myself could figure out if my 505 is blessed with a square port head or not.
    9,290
    Quote Originally Posted by zac505
    Unless the engine has been changed for that of an early 504 or it is a Diesel or Fuel Injected it will have the square port head. These were introduced in the 1979 504.
    Graham
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    If you remove the inlet manafold and they are a rectaguler shape you have a square port head if thay are round you dont
    regards jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    9,223
    You don't want to go pulling the manifold off just to check that...
    The shape of the runners of the manifold will show you... if there's an earlier model around to compare with you'll readily see.
    226
    Default ...and big bore exhaust manifolds?...
    Thanks guys. Square port it is then.
    Did the big bore exhaust manifold only come on the earlier 505's? The reason I ask is that my exhaust note is throatier than other XN1's I've heard, and I get a bit of snap and crackle on decelleration. (Perhaps this is other exhaust components though?)...zac
    9,223
    The engine pipe for the big bore manifold has its junction (where the two pipes merge into one) much further along... the 'normal' pipes join just above the bend that turns the pipe horizontal, the big bore's pipes merge after that bend.
    I've only ever seen them on very early 505s.
