306 heater/AC please help
Results 1 to 2 of 2
    Apr 2004
    10
    Default 306 heater/AC please help
    The heater/AC of my 306 is causing me major frustration. It only blows hot air....regardles of what its set to. I realise the climate controll is a lil tricky on the 306's, i havent worked it out properly yet (then again i could be wrong, maybe the things broken ). Is this a settings issue, or a faulty something? Has anyone here come acros the same thing or knows a way to get the AC happening? With summer arround the corner, i realy hope i get this thing going, as i sweat like a pig.
    Please help
    Thanx guys
    Member DanS16's Avatar
    Adelaide, SA
    107
    Howdy..
    I had a similar problem on the S16 prior to buying it. The AC came on (revs up , could hear compressor working) but only hot air thru vents.
    The problem was traced to an actuator that closes the hot air and opens a vent for cold air. The rod or component was cracked and hence not working.
    They replaced it , and its all good.
    Id take it to a specialist before you replace the AC - $$$$$
    Good luck!
    C4 Hdi - Pierre, Suby BRZ - Fuji and Wren the FRB Clio IV
