504 Coil placement
Results 1 to 7 of 7
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Default 504 Coil placement
    My coil is getting in the way.
    Currently its attached to the alternator securing arm.
    I would like to attach it to the firewall??
    Any problems with my plan? Will the increaced lead length present problems?
    I also assume that it will get jolted around less??
    thanks
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    12,269
    Quote Originally Posted by Shobbz
    thanks
    shobbz
    no problem there
    i would mount it on the passengers side inner guard though
    and yes the coil will last longer not bieng mounted on the vibrating engine
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Brisbane, Australia
    1,284
    no problem there
    I was thinking of this as well. But won't this be a fairly long distance. On the firewall i can loop the cord past the engine?
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    The coil is mounted on the side of the passenger suspension tower in the 505's.
    Nick
    1983 Peugeot 505 GR
    Brisbane, Australia
    1,284
    Quote Originally Posted by nJm
    Got a pic? Anyone?
    My visualisation skills aren't that great.
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    Late 504s have the coil mounted on the inner guard just ahead of the master cylinder.
    Gets in the way all the time... gets wet too. And that's the most important point to consider... will it get wet? Shouldn't if you mount it on the firewall...
    Brisbane, Australia
    1,284
    I ended up putting it on the left fender.
    It looks quite out of place and fairly lonely. Do coils get lonely?.
    Will see how it goes for a while. It gave me a chance to replace the dizzy to coil wire anyways. Just long enough for the 66cm coil lead that i bought
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
