205GTi did start, then didn't
    Member plasmapug's Avatar
    58
    Default 205GTi did start, then didn't
    Hey...
    I just want to ask if this has happened to anyone before.
    My s2 205GtTi had been sitting in the carpark at work all day for about ten hours. I start it up no problem, as I would expect. I drive it about 10km and then go inside. I come out say, twenty minutes later, turn the key and...nothing. Lights are good, fuel pump is good, but nothing from the starter, not even a click. I figure it has to be electrical and head to the fuse box. After checking all the fuses and making sure the relays are in, it starts no problem.
    I've had the car for almost three years and it has never happened to me before. Is it just an issue of some parts getting old or did I really just bump something out of place on the drive?
    Pete
    PS. Is there a trick for the radio security code (like some part of the VIN) or do I really have to take it to a Peugeot dealer?
    '88 205GTi
    Fellow Frogger! petermc505's Avatar
    Melbourne, SE
    172
    Wierd. I have the same problem with my 505.
    When you turn the key you can hear the fuel pump and
    everything else seems fine, except the starter motor doesn't engage.
    I've tried replacing my battery (well, I needed a new one anyway) and
    replacing various relays but that didn't solve the problem.
    I find it happens any time, whether it's hot or cold, completely at random.
    Can be annoying, but, I've just learned to live with it for now.
    84 505 GTi - Sold to a friend... written off 3 months later
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by plasmapug
    Hey...
    Try and locate the starter motor relay.
    This may be an fter market one, as many vehicles tend to loose voltage through the ignition switch with age, and most auto elecs just wire in a relay..
    These can die suddenly and without warning...
    Follow the wire from the starter solenoid and see if there is a relay conected to it somewhere...
    This would be my first port of call...
    Fellow Frogger! rogue's Avatar
    Nov 2003
    Melbourne, Victoria
    140
    i get that problem with my 205 aswell..
