Central locking blues, 505 GTI wagon
    3
    Icon5 Central locking blues, 505 GTI wagon
    Can anyone help with a starting point on my '89 GTI wagon's central locking? Unlocking the driver's door with the key unlocks all doors, but locking it won't lock any of the others. Has anyone else come across a similar fault?
    Thanks.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    Yes, happens a bit in my '83 GR sedan. As far as I know it is the actual mechanisms in the individual doors. It is fairly easy to just get a new central locking kit from JB Hifi or similar.
    Nick
    1983 Peugeot 505 GR
    3
    Default Central locking GTI Wagon.
    No, failure was of all other 4 locks (3door, 1 tailgate) at the same time. Thought it may have been the sender in the driver's door not sending a signal to the central unit, but when I unlock the driver's door I hear a relay-like clicking behind the dash. Leads me to believe it is the main CL unit not sending a signal to the other doors.
    Does anyone know if the unit repairable, and if not, is the Series 2 central locking unit behind the dash the same as a Series 1?
    Also, how do you replace the bulb in the clock in these cars? In my old STI it was a piece of cake, but the Series 2's one seems a bit harder. I have removed a cover to the left of the clock, but it's still not obvious how to remove the clock and I'm a bit worried about breaking some fragile French plastic stuff. Noticed yesterday a front parking light not working (due to a decaying plastic bulb-holder) A bit of a worry really, given the marque's reputation for longevity. This car is only 15 years old (a pup in Pug years)
    Any help appreciated.
    Dave.
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    To change the clock bulb you have to remove the whole plastic console .
    It is easy, two screws one is behind the plastic cover you removed next to the clock ,the other one is behind the ashtray
    If you undo these two screws and pull the console out from the left hand side first it will expose the back of the clock so you can change the bulb
    regards jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    Jan 2003
    Campbelltown NSW
    159
    A good article on clock bulb changing
    http://www.pcug.org.au/~mcnamee/pac/...5gticlocks.htm
    3
    Default Central locking blues
    Thanks for the advice on the clock bulb.
    The central locking seemed to fix itself after a few days. Suspect the electrics should have "Lucas" on them. Back in love with the car....
    Dave
