PUG 205 Rear limiting valves on drum Brakes
Results 1 to 2 of 2
    Fellow Frogger! AU-YT's Avatar
    Apr 2003
    229
    A question for all the learned PUG files.
    I have fittered (due stuffed bearingsin the trailing arms)A disck break rear end to a series one car.
    This setup has a much better pedal feel and just fine a "round town speeds" and will lock the fronts no problem BUT at Freeway speeds + I got a shcok when the breaks felt like they had virtually hit ice during a panic stop no locking more like over zelus ABS (no pulsing).
    Question I believe that the Drum reducing valve has a ball it that slides fowand reduces the rear pressure The angle of the valve has a lot to do with its operation the higher the angle the less restriction.
    Or should I takle this problem some other way.
    Apr 2003
    229
    This is fun I think I found my own awnser
    <a href="http://locost7.info/files/brakes/G_ValveWks.jpg" target="_blank">http://locost7.info/files/brakes/G_ValveWks.jpg</a>
    Explanes how the valve works
    Is this the same as the Pug one?
    Graeme whistle
