warning light
Thread: warning light
    Fellow Frogger! petermc505's Avatar
    Melbourne, SE
    172
    Default warning light
    Ok, I've done a search for this in two forums but couldn't find anything:
    The 'BREAK' warning light in my 505 comes on and off randomly, sometimes
    flickering, sometimes permanently on. Haven't had a new set of brake pads
    in a while. Could this be the problem? Checked the break fluid level - fine.
    What is this warning light for?
    84 505 GTi - Sold to a friend... written off 3 months later
    Jul 2004
    nth balwyn, victoria
    1,428
    could possibly be pad wear,check the little cables connected to the brake pads and make sure they are all pushed into place into the connectors properly.if they wont push in ,the pads are worn too much.
    Fellow Frogger! andrepug's Avatar
    Victoria
    454
    Could be the hand brake being a little bit on.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    It is usually warning of worn out brake pads. They must be pretty worn if they are down to the warning wire
    Nick
    1983 Peugeot 505 GR
