Remote Key Fob
Results 1 to 16 of 16
Thread: Remote Key Fob
    Member DanS16's Avatar
    Adelaide, SA
    107
    Default Remote Key Fob
    Guys & Gals,
    My S16 came with a Code Alarm remote which arms/disarms the alarm system.
    The key, is a Peugeot item, and has to be used to lock/unlock the car manually.
    I was under the impression that these cars came with remote central locking? If this is the case then presumeably i have 2 options;
    a) Buy a replacement remote key fob from Peugeot and throw the Code Alarm one in the bin..
    b) Take the existing unit to someone like Strathfields/Tonkins etc and have them code the remote to open the doors too. (not sure if this is possible tho, it has 2 buttons, one maked ARM the other DISARM/TRUNK.)
    any ideas?
    C4 Hdi - Pierre, Suby BRZ - Fuji and Wren the FRB Clio IV
    102
    My S16 came with two keys. One had the remote locking buttons, and the other was a manual key only. Sounds like you've only got the manual key. I was told (might not be true) that replacement keys ordered through Peugeot have to come from France, so might be simpler to get the alarm re-jiggied (pardon the tech speak) to open the doors also. So long as you have a manual key for emergencies you should be fine.
    However - to complicate matters - the S16 actually had a two stage locking system, the key has two buttons, one to lock the doors and another to activate the deadlocks (which prevent the doors being opened in the event of a break-in). Sounds like youve not been using the deadlocks. If you re-jiggy the alarm to lock the doors I doubt it would lock the deadlocks too. So I guess the most secure system would be to get a new remote key from Peugeot, so you can use the deadlocks, and just keep using the alarm remote to activate the alarm. *confused look*
    Damo
    Adelaide, SA
    107
    Thanks Damo...
    I think id prefer to source a new key then, funds permitting. Retain the 'original' spec and good for resale. Our other car , Magna, has remote c/l and i guess im used to being lazy..
    I dont use the alarm anyway, bloody annoying things...
    Now to see how much Peugeot want for them.. anyone want to guess
    102
    I hate to think what it will cost. My spare key had a little tag attached with a serial number, which I believe was the key code for ordering a new key from pug. I guess you're not that lucky to have the original key number? I don't know what the deal is re ordering a new key without the original number?? I'm sure a dealer can give fill you in with all the bad news.
    I'll take a stab and bid $120 for a new key.
    Member pase's Avatar
    Nov 2003
    95
    i ordered a new barrel and this came with the key stem(?) but not the actual remote
    this was about $120, plus fitting, gst etc ran it up to $200 odd dollars
    they do have to come from france, and theres a few weeks of wait
    Adelaide, SA
    107
    eeekk!
    I've sent a email to a dealer here in Adelaide, so we'll see...
    Any other places to source them? Dosen't have to be Adelaide i guess, only a small item. Anyone know of any place cheaper?
    1000+ Posts pgti6's Avatar
    May 2001
    1,619
    Quote Originally Posted by DanS16
    eeekk!
    $100 from Regan Motors Melb for a new remote central locking fob.
    You'll need to quote your Vin # & pay up front as they are useless to anyone else.
    Then you need to get the blank cut (from the other key), about another $8.
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    May 2004
    United Kingdom
    338
    Why not just get one or pair of ebay?
    The infra red remote keys can be reprogrammed to work on another Pug.
    You would just need a new key part cut from a Pug dealer.
    If you want a new key, The infra red code number is on a white sticker inside the infra red box in the roof.
    Its about 2 weeks to get a key from France to the UK, Just get a second hand pair of keys & reprogramme them or get the infra red control box & keys from a scrapyard.
    Adelaide, SA
    107
    Thanks for all the the replies guys
    $100 dosent sound too bad.. We'll see what Taylors come up with.
    pgti6, are you saying they send you the remote key as a blank, its then up to you to get it cut from the existing key? Can any keycutter cut em?
    Lee, prefer to have a new one as the rest of the car is in pretty good nick (resale), thanks for the ideas tho , good to know.
    The IR sensor your talking about,, i assume its that thing behind the sunroof/map light controls? with some small slots in the plastic case?
    Cheers guys
    Adelaide, SA
    107
    Well... Taylors came back with a price of $220 plus $8 blank key!! Regan can offer the same for $110 plus $8 blank key.
    They are both Peugeot dealers , some presumeably one must be gold plated.
    Have given them a chance to match the price otherwise i think i know where ill be going...
    Cheers.
    Dan
    Adelaide, SA
    107
    Final follow-up:
    There is a special key for the S16, as it has a deadlocking funtion.
    Unfortunately they cost $195 compared to $110 for the normal 306's.
    oh well, spose i should be thankfull for the extra security.
    Can anyone with an original S16 key with access to a digicam post a pic of there remote key???
    over & out.
    May 2004
    United Kingdom
    338
    The infra red remote key on the S16 is the same as the low spec 406 remote key.
    If you get hold of 1 or 2 working second hand keys and programme them to the car, you can make them look like new because you can get a new plastic case for the remote from a Peugeot dealer cheaply and they can also cut you a new metal key blade from the key number.
    The infra red keys are not very secure anyway and very easy to by pass, Your much better off with an RF anti grab / anti scan key with a rolling code.
    Tadpole Sil S16's Avatar
    12
    Guys & Gals,
    any ideas?
    I had the same problem when I bought my S16 - I only got the spare keys because the owner mislaid the remote jobby. I knew a new key was around $200 but that's a lot of $$$ when all you get with it is remote central locking. So instead I spent the $200 on a 3 point remote immobiliser that had a central locking function, plus rolling code, black wires, flashing blinkers, all the fruit. So now it's just one button and both the doors and hatch lock/unlock, plus you get the immobiliser anti-theft security and in my case an insurance discount. There were some VDO ones on eBay recently that looked OK.
    As for the deadlocking, when you put your key in the door lock and turn anti-clockwise to lock it, hold it for maybe 3 seconds and you'll hear a little servo motor type sound. That's the deadlocking function. I hardly ever use it 'cause I don't leave valuables in the car.
    1995 306 S16
    Adelaide, SA
    107
    Yeah, im leaning that way too now. Took it down to a car audio place at Wayville and they can programme the existing Code Alarm remote to unlock/lock the doors.. - $40
    Also means im making using of a $500 alarm i spose.
    Just can't justify $200 on a key, especially when slotted rotors and new pads would be more fun
    Thanks for all the replies.
    Fellow Frogger! MadBiker's Avatar
    Nov 2003
    Griffith
    194
    yeah its expencive, i never got the key fob for my 405, i priced one up, i had to replace the receiver unit as its coded into it, which was about 3-400 bucks all up i think...
    just need the key and the receiver really... wrekcer?
    1991 Peugeot 405 Mi16
    1994 Toyota Camry CSI
    2002 Honda CBR600F4i
    1989 Honda CD250U
    www.mad-biker.com
    May 2004
    United Kingdom
    338
    The infra red remote keys on Peugeots & Citroens can be re programmed to work on another car.
    If you pick a pair of remote keys up cheaply on ebay they can be programmed to work your own car.
    This is a simple task to do yourself or for a Peugeot / Citroen dealer to do.
