405 Mi16 front suspension knock
Results 1 to 7 of 7
    6,533
    Default 405 Mi16 front suspension knock
    Howdy,
    Oh dear; trouble already in the new Stuey machine...
    Actually, I noticed this before buying it - there's a knock in the front somewhere when you go over small bumps. You can feel it through the floorpan. My question is; is there something in the front that 'goes' and causes this?
    The previous owner reckons it's done it for years, and he named two respected Pug specialists that've had a look and couldn't find anything.
    I must say at this stage that I haven't even taken the wheels off, as I only got the special socket for the locking nuts yesterday afternoon. I'm just trying to circumvent the usual diagnostic routine if I can.
    Stuey
    Member PaulRoper's Avatar
    Jan 2003
    50
    Default Small knock ?
    If it's a small knock - could just be that the nut on top of the strut is not tight, and the washer is rattling. Will need a 7mm Allen key..
    6,533
    Paul, you're not going to believe this. That's what it was! I was pulling around on the wheel yesterday as you do to check bushes, bearings etc., and nothing. This morning, I gave it a bounce on the side I though it was on, and the strut nut needed tightening. Then I come back here - and read your post. Thanks.
    By the way, does this suggest that something's worn on the top mount which has given this clearance? I ask this because the nut's a Nylock and won't have moved.
    Cheers, Paul.
    Stuey
    Jan 2003
    50
    Default Something Worn ?
    Can't help you there, - I was just happy to tighten mine and have that darn knock go away !! :-)
    One win per day
    Mar 2003
    359
    Default 405 front end knock
    Hi - My 94 SRI had rattles from the front when i bought it at 86000kms. I thought it would be obvious what the problem was and easy to fix. Not so.
    I checked everything without dismantling, had it to 2 Pug specialists and to Pedders but no one knew for sure- I was told that it could the strut dampers.
    Being used to RWD Pugs lasting 100s of 1000s of kms. this seemed unlikely.
    I figured it would probably get so bad eventually that the cause would be obvious. 2 yrs. later it is worse and appears to be a wornout rubber at the top of the strut. Have not pulled it apart yet, but hope your tightening of the nut did the trick. I tightened one of mine so tight I stripped the hexagon trying to undo it! Good luck.
    6,533
    tresbon, mine only needed pinching up and it was very easy - no strain at all. I guess there's a rubber bush on top of the strut rod which has deteriorated.
    Stuey
    Jan 2003
    50
    Default Too strong Tresbon
    Tresbon2 - Sorry to hear you're Too Strong!
    I didn't have to tighten too much, about half a turn.
    It then got V tight, so - I left it @ that.
    Guess I was lucky.
