306 fuel leak
Results 1 to 2 of 2
Thread: 306 fuel leak
    Nov 2003
    west ryde N.S.W
    10
    Icon5 306 fuel leak
    306 1998 ,has anyone had a problem with a fuel leak from behind the filler neck after filling up with as much as it will accept but still not full on the gauge
    2000+ Brad's Avatar
    2,404
    I believe all 306's have a problem with filling up causign the pump to click off due to blow-back of gases and fuel back up the filler pipe. If this is what is happening try and hold the handle twisted to anti-clockwise until the handle bottom presses against the fuel flap which will be at about 10 o'clock, then lift the handle up in the direction of the handle. Hope this helps.
