504 Front Sway Bar Verticle Links
Results 1 to 3 of 3
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Simple question.
    How tight do you make the top nut on the verticle links?
    Its a nylon one, so I guess it isn't going anywhere, but how much do I want to squash the rubbers on either side of the sway bar.
    Until the metal rod in the centre of the rubbers is tightened on to?.
    Also should I put washers on either side of the bottom part of the verticle link? The old ones has become warped outwards. A washer would stop this but would this create less play in the suspension?
    thanks
    James
    <small>[ 20 September 2003, 11:33 PM: Message edited by: Shobbz ]</small>
    Previous
    2005 407 ST Exec
    1975 504 GL
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Shobbz:
    Yes, that's an acceptable way of doing it.
    It's also OK to put on the extra washers you suggested. I've tried it. It doesn't hurt, but it doesn't seem to offer much advantage either.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Brisbane, Australia
    1,284
    Thanks dave,
    The reason for the washers was the old rubbers had been effectively forced out.
    Granted they were probably the originals. If the new ones last half as long I will be laughing
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
