VIN Location - 306 S16
Results 1 to 9 of 9
    Member DanS16's Avatar
    Adelaide, SA
    107
    Default VIN Location - 306 S16
    Did a search, but no joy..
    Where is the VIN normaly located on a 306 S16 (MY95)?
    From Drive.com.au it suggests Drivers side door, but on mine, it is in the boot, center location where the boot meets the back of the car.
    Odd or not? or just me being paranoid ?
    Dan.
    Member Lightning's Avatar
    118
    On my 6 it is punched on to the drivers side front guard/panel (I think). Open up the bonnet and have a look at the topb bit of the guard that is normally hidden by the closed bonnet. Hope this helps.
    Toast, the best thing since sliced bread!
    Adelaide, SA
    107
    Im just hoping that it hasnt been in an accident and the plates relocated
    Drives fine and i cant see any panel damge but....
    2000+ Brad's Avatar
    2,404
    Thats the same place as mine.
    Adelaide, SA
    107
    Brad,
    the boot or the front guard?
    118
    I am pretty sure the vin can be found in both places (on the 6 anyway).
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Quote Originally Posted by DanS16
    Brad,
    its on the drivers side front guard, but its dotted on (ie the numbers and letters are made up of lots of little dots) so it can be a real pain to read. Try this trick get some white board marker(or some dirty bit of grease) go over the whole section and then wipe with a rag.... read away_chris
    ... ptui!
    102
    yeah it should be on the drivers side front guard, and if mine is standard, then it will be an unpainted section of the panel. Can be hard to read
    Member pase's Avatar
    Nov 2003
    95
    the one in the boot is standard
    i have 2 plates
