405 oil gauge
Thread: 405 oil gauge
    49
    Icon5 405 oil gauge
    I have a 94 405 with an oil gauge which reads from mini to maxi. I can't tell from the manual or the owners guide whether this is a level or pressure gauge. advice welcomed.
    Jul 2004
    27
    Dial to the bottom left of the dash? The needle should move after the ignition has been switched on but the engine not started - give it a second or two. This gives an indication of the level before the start up. It is only a cursory check - the needle on mine (a 94 405) has registered above the red with no oil on the dipstick... Needle should be against its rest to the left when the engine is running.
    dbc
    dbc is offline
    Member dbc's Avatar
    Nov 2003
    56
    Yes, its oil level, but as Pom in a Pug says don't take it as a precise indicator of level. I still check levels with the dipstick every couple of weeks, despite what the gauge says.
    It took me several weeks after owning my 405 to realise that the needle is only active when the ignition is switched on but not started.
    1969 16TS
    1995 405 SRI
    49
    Quote Originally Posted by Pom in a Pug
    Thanks,guys
    49
    Quote Originally Posted by dbc
    Thanks,dbc.
    Fellow Frogger! Rusty@'s Avatar
    234
    Quote Originally Posted by kellyo
    is yours the petrol version. I'm just a little confused cause in mine (SRDT) the bottom left guage is a glow plug load??
