505 in tank fuel pump
Results 1 to 10 of 10
    Nov 2003
    west ryde N.S.W
    10
    Default 505 in tank fuel pump
    has anyone fitted a vl commodore holden in tank fuel pump to a 505 sli in place of original ,are any modifications needed?
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    387
    Default intank fuel pump
    This is good alternative and requires very little modification. All that is required is to shorten the bracket that the pump mounts in, about 12mm if I remember correctly. Just cut the two legs off at the upper part of the base, rotate the base about 15mm and reattach the legs. Also check the rubber connecter at the top of the pump they are usually split.
    Regards Pete
    I am gunna get another 403 on the road........one day
    Echuca
    104
    Would that work in a 604?
    12,264
    Quote Originally Posted by Ropes
    you can also use a surge tank and the volvo pump that has an accumulator on it just like the 604 injection system
    the surge tank prevents the fuel pump from running dry when you corner on a low tank of fuel
    also using this method you don't need to worry about an in tank pump
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    303
    Pugrambo
    If you are using a surge tank wouldn't you still need two pumps, one to get the fuel out of the tank and into the surge tank and another to supply fuel to the engine, unless you can gravity feed it into the surge tank. This would not be possible on a 505. 604 I'm not sure. Is the accumulator you are talking about a scavenge pump separate but part of the main pump?
    Please correct me if I am wrong or let me know if I am on the right track.
    Jarrod
    12,264
    Quote Originally Posted by jarrods
    Pugrambo
    Jarrod
    on a 604 it's easy as the tank is in the boot
    the accumulator on the volvo pumps keeps the pressure constant and also keeps the pressure in the lines when the car is not running and it is located right next to the main pump
    i put this post in to reply to ropes query
    1 x 2018 3008
    Fellow Frogger! petermc505's Avatar
    Melbourne, SE
    172
    What's the advantage of putting this in a 505?
    84 505 GTi - Sold to a friend... written off 3 months later
    12,264
    Quote Originally Posted by petermc505
    well, many years ago a mate of mine and myself converted a mitsu scorpion from carby to an injection system from a magna
    now then where as the car when low on fuel with a carb going through corners never picked up air from the tank enough to upset the carb it did so with the injection
    we placed a surge tank in the car and hence the car then always had fuel for the pump to keep the pressure in the fuel lines and injection system without the need of an in tank pump
    1 x 2018 3008
    Echuca
    104
    Probably a dumb question, but when you say a surge tank, do you mean replacing the main tank or is it a small separate tank?
    12,264
    just an extra tank
    it only has to be fairly small but enough to keep the car going when the main pickup in the tank doesn't have any fuel to pick up
    we made a small alloy container that held around 1/2 a litre of fuel
    this little tank always stayed filled with fuel
    i think there were a few jap cars and even commodores around that had these little tanks as well from what we heard but we ended up making one
    1 x 2018 3008
