404 handbrake cables
    Sep 2003
    woolongong
    1
    I was wondering if anyone knows if it is posible to cut an inch or so of the handbrake cable to take up some slack.
    9,223
    Easier to get cables made up, I'd say...
    Though there is another way. The slack can be taken up by moving the mounting for the outer cable further from the joint in the cables. Just drill a pair of holes through the floor and put some 8mm bolts through.
    Mar 2003
    lake illawara
    190
    Would that mean move them further forward, good idea if it works . The actual cable would still be the same length I'll give it a try tomorrow What is a good shock absorber to use on the rear end of the 404 sedan, not a lot of dosh available. regards, cane toad.
    9,261
    The LIP shockers sold by European Auto Imports are excellent.
    Graham Wallis
    9,223
    No, you move the mounts back... so you are allowing more length to be absorbed by the run from the lever under the floor and the start of the enclosed section.
