505 front blinker
    Nov 2003
    west ryde N.S.W
    10
    Icon5 505 front blinker
    how do you remove 505 sl front blinker from bumper bar to change bulb
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    Just push in on the outside edge of the light panel and the inside should 'pop' out. Then just pull the whole unit out and the globe holders can be removed from the rear of the unit.
    Just be careful as the lens may be fragile and the spring might be stiff, otherwise it's a piece of cake.
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    Nov 2003
    west ryde N.S.W
    10
    thanks
    Member LynCliff's Avatar
    Cohuna Victoria
    94
    If you look up under the bumper bar at the inside end of the light fitting you will see a plastic lug sticking out that locks the fitting in place. Just push it up then out to remove light fitting,
    Lyncliff
