Chnaging 504 ignition switches
    Jul 2004
    Melbourne Australia
    5
    Default Chnaging 504 ignition switches
    I am about to change ignition switches on my son's 1978 504GL. There's nothing of help in my Haynes manual. The key still turns in the lock quite freely. I gather that the key must be turned before the unit can be withdrawn.....but to what position? Could somebody please explain the procedure for removal and fitting and advise me as to any particular points of caution which I may need to watch out for.
    Thank you
    12,266
    there is a small bolt holding the switch in and there is also a pin that you have to push in when you turn the key to line up with a dot i think on the switch
    the pin is underneath the switch
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    On some you turn the key to accessory and on others to just past accessory to a little dot.
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    Jul 2004
    Melbourne Australia
    5
    Default Thank you
    Thank you fellow Peugeotists. I've been out to European Auto Imports (quite a drive from Mt Eliza now that Basil has shut shop), bought a new switch and now I see how the whole thing works.
    Thanks again
