New clutch for Pug 205 GTi
    Fellow Frogger! Pug-a-lug's Avatar
    Jun 2004
    172
    Default New clutch for Pug 205 GTi
    Ok, I think I need a new clutch
    The car has done about 171,000 kms.
    It isn't 'slipping' per se... but there are rather nasty low-frequency grinding noises eminating from the drivetrain during initial acceleration from rest... as well as under any hard acceleration.
    It may be a drive-shaft issue (which is what I initially thought)... but the way its been evolving over the past few weeks, I think its clutch.
    My question : How many people here have had their clutches replaced and roughly how much did it cost? (parts + labour)?
    392
    Check your engine mounts you may find that the bottom of the exhaust is hitting the cross member on acceleration cus the engine tilts back.
    I also had similar sounds thinking it was a drive shaft grinding and after replacing my cat the sounds where gone.
    Hope it helps
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    You can get a clutch kit fron auto france in artarmon for 250 bucks from memory.
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Jul 2004
    England
    11
    Default Maybe?
    It could be a drive shaft, the longer drive shaft has a bearing on it, fits in to the lower engine mount bracket. To see if it is, spary some WD40/greese spray around that area of the bearing-Take the 205 beast for a drive.
    See if the sounds still there.....
    Good Luck (could be the clutch still, as you have clock up some miles-no....KM)
    Member jamin's Avatar
    71
    Got my clutch replaced about 2 months ago.
    It was $350 for the kit, labour was about $650 but I got the timing belt, water pump, main seal and a heap of other stuff done as well.
    So i'd guess just for the cluthc the labour would cost about 300?
    I got it done at Elliot Tune mobile, he's based in moorabbin, go to:
    http://www.frenchgarage.com.au/ for contact details.
    Jamin
    Jun 2004
    172
    Just an update. I noticed the other day that my exhaust was sitting a little lower than normal... and indeed a support bracket seemed to have come loose.
    So I took the car to get a minor service (ie fix leaking master cylinder) and asked them to check the exhaust.
    They fixed it up.... noise all gone!! Vibration all gone!!! Car is running smoothly again .... HOORAY!! It's like a brand new car
    immy s16 - a gold star for you
