505 reverse gear engagement
Results 1 to 12 of 12
    Fellow Frogger! tassiediesel's Avatar
    Jul 2004
    Tasmania
    175
    Default 505 reverse gear engagement
    G'day.
    My 505GTi has problems when I ask her to go backwards. At first she is reluctant to engage reverse (crunching of cogs) and then she slips in and refuses to come out again! I can feel a "lurch" as the gear finally engages. Through necessity my wife and I have now got the knack of getting it out of reverse, however it can be a bit embarassing when it gets stuck in a carpark. I suspect the detent springs and plungers on the selector shaft. Any ideas?
    Hobart
    1,496
    Is it an Auto ?
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Jul 2004
    Tasmania
    175
    Default 505 GHTi reverse
    No...It's a 5 speed. And other than the problem with reverse, a beautiful 'box!
    82 Peugeot 505 Turbo Diesel
    78 VW Golf diesel
    80 VW Golf diesel
    84 Nissan Patrol MQ diesel
    Hobart
    1,496
    Could just be a slogged out linkage.....
    They are fairly easy to replace once the console is out..
    Ben
    1973 Peugeot 504 GL
    9,223
    While it could be a detent issue, it actually sounds like the symptoms you'd get with a clutch that's dragging.
    Is the clutch fully disengaging?
    Jul 2004
    Tasmania
    175
    Default Dragging clutch???
    Thanks for the suggestion! Nope...It's sweet. In fact, one of the nicest around. No problems with any other gear, no "sinking pedal", noise or any other indication that it's the clutch.
    78 VW Golf diesel
    80 VW Golf diesel
    9,223
    You miss my point...
    The synchros would tend to mask a slightly dragging clutch in the forward gears, but in reverse there is no synchro.
    How far from the floor is the pedal when the clutch engages? With air in the system this might even be misleading.
    Jul 2004
    Tasmania
    175
    Default Not the clutch dragging
    Thanks, Ray. No, I checked out the release position and it's about one third down in the pedal travel. I held the clutch just beyond that point with the engine running for a couple of minutes and there was no upward creep. Looks like it ain't the clutch!
    78 VW Golf diesel
    80 VW Golf diesel
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    387
    Default 505 clutch
    I would be inclined to check out the clutch master and slave cylinders before I went looking for gearbox problems. I had a similar engagement problem and found both cylinders had problems.
    Regards Pete
    I am gunna get another 403 on the road........one day
    Parramatta
    1
    Default 505 reverse selection
    This problem is usually wear in the selector forks or even a bent fork. Pull the rear housing off the box and it will probably be obvious.
    12,266
    Quote Originally Posted by Ian Robbo
    Ian
    are you "the" Ian robinson that is a member of the NSW pug club and is also a mechanic, around 5'6"-5'7" ??
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    ...of lightweight build, sometimes (when the need arises) disguised with a beard?
    Gotta be him, 'rambo. They let anyone in here!
    Also a generous soul, by the way, gave me a pile of torque tubes when I needed them to build my garage...
