Mi16 Fuel injectors
Results 1 to 9 of 9
    Jul 2004
    Toronto, Canada
    12
    Default Mi16 Fuel injectors
    Does anyone know the part number of the fuel injectors for the Mi16 (XU9J4Z)? I know that the approximate power limit support is 180hp. And they flow at 214cc/min. I want injectors that will support 220hp. Are there any interchangeable ones that will work with the stock engine management? Do you think 270cc/min injectors will work? What cars can i get fitting ones from? Any help is much appreciated.
    Thanks,
    Piran
    Jul 2004
    England
    11
    For my MI 16 the part no. of the injectors is 280150762 this is not a pug part no. but a Bosch no.
    Go on the bosch web site, there is a shed load of info and you may find a better injector.......
    7,483
    Find a 4 cyl. car that has a capacity of 2.5-3.0L. Anything bigger than 214cc isn't going to work with the std. ECU. You'll need a programmable ECU to do it properly.
    Ipswich, Queensland.
    1,911
    Generally 5cc =1hp in injector sizing, so a set of 270cc injectors would run around 215 Hp. PeterT is right about needing a programmable ECU if going on the Hp trail, as big injectors would probably make it too rich down low. If using the standard ECU, the resistance of the injectors would need to be kept the same. eg. 16 ohms
    Competition injectors can be as low as 2 ohms, and as such require a much greater amount of current to be energised. These injectors will handle much higher fuel pressures, but doubling the pressure will not double the fuel output.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    brisbane
    2,899
    i have been told that Magna ones fit and are cheap for the mi16 [i personally use Evo ones ]
    cheers jr
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Jul 2004
    Toronto, Canada
    12
    I know there are some BMWs that used the Bosch Motronic M1.3 engine management. I'm not sure which ones. Maybe they use bigger injectors? By the way, my car is chipped, it was programmed by this guy in Germany. The rev limiter is set to 8400rpm, but no i don't take it past 7500rpm. Maybe the chip can handle the extra fuel? I was also thinking Volvo 740 turbo injectors. A programmable ecu is really out of my budget i think. Any other input?
    1,911
    Try going to www.wolfems.com.au and look at the support section for a long list of injector types and their flow rates.
    7,483
    Have a look at this site:
    http://www.rceng.com/technical.htm
    according to the calculator, you need at least 300cc/min for 220hp
    Jul 2004
    Toronto, Canada
    12
    What is the BSFC for the XU9J4Z?
    Maximum Injector Duty Cycle?
    System fuel pressure at fuel rail?
    What does that Wolf 3d engine management cost?
    Still confused
