405 interior fan noise (when fan selected off)
Results 1 to 9 of 9
    Jul 2004
    16
    Default 405 interior fan noise (when fan selected off)
    Hi everyone,
    I've recently purchased a beautiful '94 405 SRI after owning an '89 405 for some time. The upgrade was well worth the effort!
    However I want to try to either stop or quiet down the interior fan (or something) which is very noticeable when the key is in the ignition and the engine hasn't been started.
    The fan (or whatever it is) sounds like it is located in front of the front passengers feet.
    Has anyone had a similar problem or know how to fix it?
    I figure that if it is a fan my two options are to either stop the fan from operating when the engine is stopped or to replace or clean the fan and bushes.
    Any comments would be much appreciated!
    Thanks in advance,
    405 fan.
    7,483
    Quote Originally Posted by '94 405 Fan
    Hi everyone,
    Thanks in advance,
    405 fan.
    The fan never actually stops, thus wears itself out. New fan.
    Jul 2004
    16
    Fair enough. Is the fan purely ventilation or will there be any serious consequences if I disconnect it?
    The fan makes quite a bit of noise- gets a bit annoying.
    BTW I just realised the irony of my user name and the subject of this post....
    12,266
    to prolong it for a little while you can try some CRC2.26 on it and see how that goes but a new fan is something i can see in your future
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    May 2004
    United Kingdom
    338
    Hi
    Its not the cabin temperature sensor fan is it???
    Turn the ignition on & stick your ear next to the little grill on the dash board just above & to the right of the glove box door.
    If it is this, Prise the grill out, suck the fluff out with a hoover & squirt a drop of WD40 oil on the little fan.
    PS, You do learn to ignore the nosie after a while.
    Fellow Frogger! tasgill's Avatar
    Toowoomba
    290
    I have also had something come through the vents ( had been parked under a tree ) and get tangled up in the fan. I ran the the motor flat out for a while and the noise disappeared.
    Terry
    405 dt
    Jul 2004
    896
    The fan is easy to remove. Check it doesnt have a leaf or some grot in it.
    I was concerned about mine running all the time so I took it out to check. I cleaned it up and oiled the bearing felts (I cant remember the specifics as this was about 3 years ago) But it has never played up. It runs very slowly to keep the air moving to assist the climate control.
    If it is a bit noisy it may be running fast due to maybe the fan speed slide control playing up.??
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
    Aug 2002
    1,290
    I have a spare climate control fan, the little one in the dash and the ventilation fan also. See the post on s2 405 parts.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Fellow Frogger! tassiediesel's Avatar
    Jul 2004
    Tasmania
    175
    Default Fan noise
    The same problem with my 505GTi. I can't see an easy way of removing the fan to lube it. I have drilled a small hole in the air intake to the fan and inserted the spray tube from a can of WD40 so that it stays there permanently. When the fan gets noisy I connect the aerosol can and give it a quick spray with the fan motor switched on. Does the trick for about a week. I guess this must be a "farmer-fix"!
