GTi6 engagement problems..
Results 1 to 19 of 19
  • 1 Post By GTI145
Thread: GTi6 engagement problems..
    May 2004
    Melb
    75
    Default GTi6 engagement problems..
    last night i was driving home and then totally out of the ordinary the gearbox like locked up, and i couldnt down gear or even select a gear, it was like the synchros were not lined up but for every gear, it was ok when i was gearing up but on down gearing it was giving me a serious head ache, it could be a linkage problem between the gearstick and the box but when the car is off it drops into the gears perfectly so i figured that if it was a loose linkage it would do it all the time, it only did it when it was warmed up though, anyone experianced this before???
    the car is nearing 100k now so i was expecting stuff to go wrong, its natural but i couldnt even drive it i had to stop and try to get it into 1st for like five minutes, it may also have something to do with the clutch....
    regards
    Roman
    Member Lightning's Avatar
    118
    When was the last time you changed the gearbox oil? Similarly what condition is your clutch cable in and when was the last time you changed the clutch. I noticed a huge difference when I changed the gearbox oil as these gearboxes do have trouble changing from time to time. Similarly with the clutch cable. If you can't depress the clutch pedal far enough you will have trouble changing gear. These gearboxes do have a shifting problem that seems to come and go as it pleases.
    Toast, the best thing since sliced bread!
    May 2004
    Melb
    75
    yeah it seemed like the clutch wasnt in all the way but it was as far as i could get it in, so i will look at the clutch cable and clutch itself. as far as the gearbox fluid, i dont know i havent checked it, everything happened in the dark and i gave the car to dad this morning to show mechanic near his work, just so see. but anyway the car is really annoying me at the moment. i love it to death but god damn its tempermental
    Member pase's Avatar
    Nov 2003
    95
    i had a similar problem but i couldnt put it in reverse
    this was pretty soon after i had changed the clutch cable after it snapped
    this only really happened once or twice and havent had any similar problems for a while
    May 2001
    Sydney, NSW, Australia
    3,634
    If you turn the engine off, can you change between the gears? If that's a yes, it's probably the clutch.
    Gearbox oil is important in these boxes too... I can't remember the *exact* oil, but it's Neo brand, and it made a big difference to the smoothness of my box (which is different, albiet related).
    Derek.
    1000+ Posts U Turn's Avatar
    1,761
    Quote Originally Posted by evolvetoGTi6
    btw the cost of replacing the 6-speed gearbox in the gti6 is about 7 grand if it was to go totally cactus Probably worth taking it to a pug mechanic to have a good look at.
    Take the long way home....
    - 306 gti6
    Gordon, NSW
    4,527
    Sounds like the clutch to me, too.
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    When I got my clutch cable replaced it was tough as anything to change gears. What actually happened was that the person who reinstalled it didn't adjust it properly. After it was adjusted, the gear changing was a lot smoother (well as smooth a change as a GTi-6 gearbox can get )
    I think next service I might try one of these boutique gearbox oils to see how much better it makes things.
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    392
    Yeah sounds like a cluth cable
    On the other hand for smoother gear changes try using some Nulon G70 its about $12 and makes a hell of a smooth gear change.
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    Roman u fag...maybe if u didnt drive a gay french car then these things would not go wrong
    Go put Redline Gbox oil in ur car i just put it in mine its good
    I gotta go put the redline engine oil in this week too
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Gordon, NSW
    4,527
    Yep, Redline is a good product. Lubing the clutch cable is a good idea.
    We eventually had to replace the entire clutch after it was acting up like this though.
    May 2001
    3,634
    Do we really need this WRCPUG? Pull your head in.
    Derek
    12,265
    Quote Originally Posted by WRCPUG
    Roman is good at lubing up his areshole so i think hell be a expert at lubing up his clutch cable
    mate please edit this or i shall delete it
    thank you
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    May 2002
    1,035
    Im sorry Mr serious ('s)
    Ill just give roman crap in person next time i see him.
    Consider my post edited.
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    May 2004
    Melb
    75
    hahaha, alex man dont whore my thread you weiner
    Thanks peeps, it was the clutch cable, but now there is a new one in place and the pug is beautiful again, they also gave me a new battery and earth strap which has fixed the other probs i was having, yet to see whether or not the idling problem still occurs but i doubt it will, the only thing that could have been doing it was the stepper motor on the inlet, so they said to keep an eye on it but it was probably to do with the electrical probs i was having.
    May 2002
    1,035
    Hey roman next time i see u do u mind if i feel ur gearbox engaging..like the synchros and stuff? Cause i want to compare to mine...i dont think mine is as smooth as its meant to be esp 1st gear
    Also can i see how much ur engine flexes as i think i might need to get sum Group N mounts as my rubber ones just flex too much.
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    May 2004
    Melb
    75
    yeah cool, let me know when you wanna hook up...and we can do the banana dance yipppeeeeeeeee!!1
    May 2004
    Melb
    75
    what, is it always a pig to engage or just when it is still cold? you know they are a bitch of a box in the cold.
    Member GTI145's Avatar
    Jun 2004
    54
    On the GTi-6,the RHD design puts the clutch cable right passed the exhaust manifold,where it binds up the internals of the cable causing a heavy clutch feel.If your clutch is heavy and not engaging correctly try replacing your cable.
    If you can't select gears,check your link-rods on your selector shaft - these are little brass rods about 10cm long with small ball joints at either end that bend or wear out.
    These rods are very important in gear selection,they all link up to a main ball-selector lever.This lever has a habit of bending or fracturing,it also has an inner and outer bush on the base which are plastic - these crack!
    There is another selector arm where your clutch cable joins the gear-box - this also bends.
    These rods,lever and the bush's are all cheap.Replacement will improve gear selection or fix any selection problems.
    GTI145
    TrinityJayOne likes this.
    '89 405 MI16
    '00 206 GTI
    '04 206 GTI 180
