What Carbie Do I Have on My 504???
    Fellow Frogger! Peter J's Avatar
    Jul 2003
    Dubbo NSW
    198
    Default What Carbie Do I Have on My 504???
    Hi all,
    Been under the bonnet of my 1977 504 GL with the Haynes manual looking at my carbie from all perspectives and I cannot figure which one I have. Doesn't appear to look like any in the manual.
    It has the oval shaped rubber top fitted neatly from the air cleaner so I presume it is standard .... but which one? The only markings I can find on it is a small wagon wheel type shape with spokes with "A-3" written above it.
    Any ideas?
    Sorry about such a silly question?
    Regards
    Peter J
    PJ
    Fellow Frogger! Janek's Avatar
    May 2004
    Sydernee
    200
    i think youd need to give us a lil more info... how about all of the markings, etc... i have 4 504 carbies, all stock, all different... 3 solex and one weber.
    what exactly are you looking for that you need to know the type of carby? the manual should give u locations of teh idle/air mix screws, and this should point you in the right direction if you cant find it at first
    -Janek
    Jul 2003
    Dubbo NSW
    198
    Thanks Janek,
    I was locating the idle screw etc in an endeavour to help me identify the carbie ... but could not make a match ... sorry ii cannot find any other markings on it other than those given above.
    I was just interested in exactly what carbie it was so I could perhaps seek views of the performance of the carbie and also for future reference if any work needed.
    Peter J.
    PJ
    May 2004
    Sydernee
    200
    will get back to you tomorrow, after i have a quick squiz on mine, and my manual... by the afternoon i'll get back to you... sounds like a solex carb to me...
    Fellow Frogger! AlsPug504's Avatar
    310
    Default What Carby
    More than likely You have a solex 32 - 35 seia. There are quite a few variations to the air cleaner fittings. if it looks like two singles it is probably 32pciba and 32 s
    The aircleaner can be cyclonic with a right angle rubber fitting on the carb. Or a large rubber donut that is clamped to the top of the oil bath. None of the manuals I have seen show the oil bath arrangement so it can be quite confusing.
    Al
