306XT advice please
Results 1 to 18 of 18
    Jul 2004
    Sydney Australia
    3
    Icon5 306XT advice please
    hi - I'm looking at buying a 1999 Peugot 306XT, in good condition for around 14K. Do you know of any standard problems I should be looking out for before purchase? Thanks.
    392
    Jus like most pugs look for the service history and make sure all servicing has been done at the correct intervals.
    May 2001
    Sydney, NSW, Australia
    3,634
    Cam belt is the key thing on 306's of that age.
    It's a 1999 model- cam belt should have been changed last year, or at 80 000km. It's a 4 year/ 80 000km service interval on the cam belt. About $800 to have someone do it for you.
    Other than that, I'd expect front disc rotors to be worn out, or already have been replaced, especially if it's an auto.
    Derek.
    Jul 2004
    Sydney Australia
    3
    Icon10
    Derek.
    thanks very much Derek. The belt and water pump have both been replaced recently, and it's a manual. If these are the main things to look out for, I think I've found a bargain!
    Sep 2003
    North Parramatta
    3,997
    Don't forget about the discs though. 306s tend to chew through the rotors before the pads are worn fully!
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    melb
    4,379
    its a good car, beit a slow one. Very reliable & economical, i'm quite content with mine even if it is slow.
    Jul 2004
    Sydney Australia
    3
    Icon7
    thanks everyone for the advice - much appreciated.
    1000+ Posts TroyO's Avatar
    2,511
    Quote Originally Posted by purrr-geot
    Oh I don't know the 16 valve versions (which a 1999 model would be) go reasonably well, they have nicely flexible engines.
    I have heard clutch cables can be problem at times. The clutch action can get stiff after a while.
    Troy.
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    we own a 97 model XR... its basically one of the first N5's and has the 1.8l 16v, its definately not slow by any stretch of the imagination or at least i wouldn't call it slow... either way though these cars aren't trafic light racers... if you want a trafic light hatchback go and buy a civic... if you want all the information there is read the 306 timeline FAQ... while i'm here does anybody know the power output of the 1.8l 16v and the engine code... i've never botherd looking into it as mum takes the car back to the delaership for servicing and what not anyway
    May 2001
    3,634
    By 1999, the 306XT (in Australia) had the 2L 16 valve 100kw engine. It's plenty quick enough. The 1.8L 16 valve engine is pretty damn good too
    Derek.
    1000+ Posts brenno's Avatar
    1,937
    To clarify, the 2 litre engine came on board late in '99.....and were technically a MY2000 model.
    When I sold my '99 build 2000 model 306, I advertised it as a 2000 model so there was no confusion. Most of the '99s had the 1.8 (which is by no means a bad motor, it just lacked the mid range torque of the later XU10J4R's)
    melb
    4,379
    My apologies, the 8v is a slow slug, but yeah the 16V sounds quite good.
    And yeah the clutch just get stiff,
    hope you dont drive around the city like i do
    10,945
    At risk of starting/renewing this debate, I disagree about the 306 8V being a slug. Not as quick as some, but for town use seems pretty adequate, and that flat torque curve is good for traffic. Cruises well at all legal speeds (and at 160 kph+ if required, as I know from experience, even with less than 1.8 L motors).
    What I'd be looking for is service records for coolant changes. If the cambelt has been changed, that's one key worry dealt with. Worn front rotors are a trivial matter (ours lastest nearly 90,000 km so they don't wear ludicrously unless abused I'd say) but internal and heater matrix corrosion certainly are not trivial.
    Good luck with the purchase.
    Gordon, NSW
    4,527
    Quote Originally Posted by macquered
    and it was a great car!
    1,937
    Too right it was! Still scratching my head over that one.....a freakishly capable car given its humble origins.
    1000+ Posts zykyra's Avatar
    Apr 2003
    Perth
    1,199
    Have you considered a Xsara? Almost the same car but I believe better looking with a much better ride ....................oops, is this the wrong column.........
    http://www.drive.com.au/used_cars/ci...&pg=1&pp=4&d=0
    http://www.carsales.com.au/pls/carsales/!cs_content.private_vehicle?vehicle_id=118062&curr ent_rec=3&total_rec=3&sort_type=&make_id=53&model_ id=2799&state_id=-1&search_distance=25
    http://carpoint.ninemsn.com.au/marke...=1&chkRows=500
    1972 DS Pallas
    2015 Clio
    2012 DS4
    Simca Arondes (travaux en cours)
    Lotus Elise Club Racer '12
    In WA? Join THE club ! www.frenchandfantastic.com.au
    2,511
    Ahh, it's no major problem, you just grow a bigger left leg
    Troy.
    Jul 2004
    896
    My wife's 98 306 XT wore an outside rear brake pad down to the metal and scored the disc at about 40k. My Pug mechanic said this was a problem with this model as the calipers werent lubed properly to enable it to slide so as to equalise pad pressure on the disc. Anyone else had this problem?
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
