HELP : how do you get the front bar off a '98 306 xt?
Results 1 to 3 of 3
    Jun 2003
    270
    well... how do you get the front bar off a 306?
    Peugeot 306, garrett GT25 turbo, 3" exhaust, microtech LT8 ECU, 16.7 psi, front mount cooler, Chris Milton race port&polish w/ 3 angle cut valves and redesigned combustion chamber, 186hp atw for now... injectors ran out of puff
    NOS COMING SOON!
    12,266
    ok
    i have taken mine off the GTi-6 a couple of times
    there are 4 bolts on mine holding the bar on
    you need to remove the inner guard linings from the front wheel arches
    in there you will find 4 (2 on each side) 13mm nuts
    on the passenger side one is buried so you will have to use a little nouse to get to it
    on the drivers side you need to remove the washer bottle to gain access
    then on each side there are 2 bolts that operate a clamp type arrangement that you need to loosen and the front bar just about falls off
    once you have done it once it's about a 15min job to remove the bar
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jun 2003
    270
    cheers for that. do you know if there are any problems if you want to re-locate the fuse box? (the one in the engine bay)
    NOS COMING SOON!
