Blak smoke when engine revs increased
Results 1 to 11 of 11
    Dec 2001
    37
    Default Blak smoke when engine revs increased
    XU 1900 engine+ solex 34/34 on 405
    In the morning: Blak smoke when engine revs increased
    (carb had been cleaned)
    Well looks like extreamly rich mixture.
    Choke diaphragm looks ok !
    What should I do??
    Thans.
    May 2001
    Sydney, NSW, Australia
    3,634
    An XU family engine with a carby? Sheesh, I didn't know such an antiquated thing existed! I thought the XU engines were designed for the front wheel drive cars - all modern cars which had electronic fuel injection. What country are you in?
    Anyway - you're sure the choke isn't stuck on? Do these carbys have an automatic choke?
    Derek.
    Dec 2001
    37
    Default Do these carbys have an automatic choke ?
    Yes !
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    yep they exsist, i didn't know these exsisted in xu9's but my car as well as most others with XU5's except the 205 GTI if i recall corectly are a carbie setup as are the 205 SI... and i think 205 automatics that were sold over here... as they were all xu5's as well afaik. anyway the webber thats on mine has automatic choke, but then its a difrent setup
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Derek.
    Should have looked more closely at the FCD, my Bx is an Xu with a carb.
    Dave
    Dec 2001
    37
    Default The smoke...?
    OK we referd to xu &carb...
    What sould I do with the smoke...?
    Sunshine Coast
    4,520
    have you tried adjusting the mixture and / or idle rate i know that may sound basic but it might help... is the butterfly on your carb not closeing properly is another thing as it could be sucking air and therefore not getting a corect mixture
    Apr 2001
    1,340
    Quote Originally Posted by JLavi2002
    Triple check that the choke is opening up when its warm, next check the float level. Also check that the jets are standard for the car.
    You said this happened in the morning, does it go away when the car is warm? (when the choke is off)
    Dave
    Dec 2001
    37
    Default Last Data..
    Mid day temp out 32c. car rested for 7 h.
    Choke baterfly open 2mm.
    Start engine choke opens to 5-6 mm.
    deprsing exelerator rev up to 4000, black smoke choke bterfly in vertical position.
    Driving 4 mills : engine in normal temp. Choke baterfly vertical.
    deprasing & exlerating (parking) baterfly vertical and....black\brown smoke...
    Help!
    Fellow Frogger! tasgill's Avatar
    Toowoomba
    290
    Not familiar with the 405 Solex, but I had a similiar problem on a 505 and it turned out to be a pinhole in the power valve diaphram.
    Terry
    Nov 2002
    Yarrabilba, Queensland
    2,758
    Help!
    Sounds like the actual choke mechanism is still operating. May-be the choke needs some adjustment? Do you have a repair manual for the car? Check throught the fuel system section and find the auto choke settings. It may be adjusted for a wide cold opening and not completely returning to a static position when warmed up.
    Good luck
