95 Mi16 Making very awful noises
    Christchurch, NZ
    228
    Default 95 Mi16 Making very awful noises
    My Mi16 expired this morning. I was doing a u-turn to park it and it started making a god-awful clunking noise from up front somewhere. I switched it off and counted to ten very slowly, and tried to re-start it. It makes loud clunks on the starter and is trying to run.
    I am waiting for the tow truck to take it to my mechanic.
    His thoughts are cam-belt (last one done 55 000 km ago).
    I am clutching at straws, but am hoping the cat. may have collapsed and completely blocked the exhaust, as I once had dreadful German car which had the fibreglass stuffing inside the muffler let go, and you would have sworn the thing had crapped itself when trying to start it.
    Bloody modern cars. Hate the bastards (unless they are going properly)
    95 MI16
    71 404 U10 ute
    66 404 coupe
    55 203C (gently warmed) gone... sold...
    12,266
    have you looked under the timing cover to see if the belt is very very loose ?
    that will give you a very good sign about the belt condition
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Quote Originally Posted by kiwi 03
    Hi,
    If it was still running when making the noise it is not the cam belt as the cams drive the distributer & valves. Could possibly be main or big end bearings or a cracked piston but there are realy losts of things it could be.
    Christchurch, NZ
    228
    I am a mechanical moron, so have just sent it to the expert rather than my going near it with a spanner and buggering something. I am well aware of my shortcomings under the bonnet, so I don't touch things I don't understand.
    95 MI16
    71 404 U10 ute
    66 404 coupe
    Christchurch, NZ
    228
    Well, I have the diagnosis. The engine was falling out.
    Gearbox mount has snapped and the whole thing was lying on the bottom crossmember. Managed to stuff a cv boot at the same time- ripped it to bitson the crossmember.
    Mind you, the mechanic still can't actually get the damned thing to run yet, so it may have disturbed something else in the process.
    Bloody cars.
    95 MI16
    71 404 U10 ute
    66 404 coupe
