504/505 handbrake adjustment
    Lilydale, Melbourne
    2,095
    Default 504/505 handbrake adjustment
    My brother just had his 504 serviced by a mechanic, not a Pug specialist, but a good mechanic. He adjusted the handbrake so it only takes about 3 clicks to fully engage it.
    I seem to remember reading in Torque that when a 504/505 handbrake is properly adjusted it should take 10-12 clicks to fully engage. If it's set to 3 or so clicks there can be problems.
    Anyone know?
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
    Fellow Frogger! Ranger's Avatar
    Launceston Tas
    143
    HI john,
    I Just checked in Haynes 505 (no 762) shop manual
    "Check that the handbrake is fully applied betweed 4 & 7 notches for vehicles with rear drum brakes and between7 & 13 notches on vehicles with rear disc brakes, if not, adjust the handbrake as described in section 18 "
    section 18 in brief ; safely elevate vehicle, chock wheels, use axle stands , handbrake off, get in under, slacken locknuts, adjust each side equally, check the outer of the cable is seated properly, test for 4-7 or 7-13 clicks, do up locknuts, 10 minutes max . open a beer.
    Knowledge is the best defence against "helpfull" people. a workshop manual will pay for itself many time over.
    Cheers Ranger
    "The defendant is no gentleman, but that is neither here nor there. We find for the defendant, much as we dislike him." A.P. Herbert
    Dec 2002
    CANBERRA
    400
    Hi, if they are not at 10 or 12 clicks there is not enough movement for the automatic adjustment in the calipher to work properly (ie it can't move to the next notch on the ratchet and therefore adjust for pad wear). The handbrake will work well for a short while and then "go off".
    Jim
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Quote Originally Posted by pug303
    Jim
    I was playing around with my handbrake last weekend.
    Honestly the best thing I did was to force some rubber grease down the casing. Not the best stuff, but does the job necely for now. Hanbrake is so easy to apply
    I read the manual re the 10 clicks. My cables seem to be slightly un even, so i just removed a bit of the slack in the cable, whist looking down at the cable from within the car. This gives me ~ 11clicks. Handbrake works well. Needs some further adjusting to be able to hold more than just me in the car though
    I don't know If i could adjust each side equally, But i did my best
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    Lilydale, Melbourne
    2,095
    Thanks indeed gentlemen (I assume you're all blokes...). We will fix.
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
