Im Leaking Fuel
Thread: Im Leaking Fuel
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,454
    Default Im Leaking Fuel
    Hay all..
    My 83 505 STI is dropping a bit of fuel just up from the pump at this litttle thingy that looks as if should have a hose running off it.. ??
    Its a small cylinder in shape, and has a little nipple on the end pointing towards the ground where fuel is droping when pump is on and engine ticking over..
    Can i just tie a cable tie around it and stop it.. or is it something more important which serves a usefull role in regulating the flow of fuel, and should have it repaired, replaced?
    Aug 2002
    3,454
    anyone got any ideas??
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    388
    Default leaking fuel
    Sounds like what you are talking about is the fuel accumulator. Its function is to keep fuel pressure in the system when the engine is shut off, so that you dont have to crank the crap out of the engine to start it. If its leaking it may be stuffed? Regards Pete
    I am gunna get another 403 on the road........one day
    Aug 2002
    3,454
    ahhh cheers.. .. so its a rubbery valve type thingy.. just nee to replace it and she'll be allright?
