Can you run a PWR steer rack unassisted
Results 1 to 10 of 10
    303
    Default Can you run a PWR steer rack unassisted
    Does anyone know how the power steering racks in a 604/505 work. It is my understanding that the steering input shaft is not directly connected to the pinion but somehow twists slightly and in doing so tells the pump how much assistance to apply to the ram.
    I had an unassisted pwr steer rack in a 504 many years ago and while it performed ok at first after a while it appeared to get sloppy. ie where you could turn the input shaft slightly and the pinion would not move. It appeared that the power steering head had been damaged.
    I have heard of many people doing this but have not heard of any similar complaints.
    My reason for asking is that my 1/2 share 505 turbo V6 racecar is nearing completion and we look like having to run the rack unassisted. We want to retain the rack because it is a quicker ratio. We are running a PRV V6 with a left had bell housing and even by turning the pwr head upside down we cant get it to fit with the starter, clutch slave and turbo crossover pipe. We tried moving the rack across but this didn't seem to work either. I am going to investigate whether right angle fitting out of the pwr head will work. I am worried that the higher loads place on the rack (wider race tyres, higher speed etc) will create a bigger problem than I had in the 504. And I'd hate to think of the conscequences if it let go.
    Hope someone can be of some help
    Jarrod
    303
    Or is it possible to transplant the rack and pinion into a manual rack housing?
    Jarrod
    12,269
    well as far as i know 2pugs is running the power rack in his 604 without hoses and it seems to be working fine which tells me that the valve on the rack only powers the cylinder to assist in turning and there is a direct link through the valve to the rack
    the thing to remember is the orbital valves are a bit like a pump in that they move fluid as well and direct fluid
    all 2pugs did was turn the valve around to clear everything but left it in place
    the other thing you could do is modify the bell housing and mount the starter on the other side to give you a bit more room
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I drove my 505 STI for about 6 months with the power steering pump removed. It was vague on centre, but that was due to previous wear on the rack itself. The play never seemed to get any worse in the 6 months that I drove it like that, and it wasn't all that heavy to steer either. The only reason I changed it to a (slow) manual rack was because it was sloppy and because I had plenty of normal racks.
    I plan to run a lightened 504 in future with a 604 rack without the pump. I believe these racks are more likely to be in better condition, because it's easier for owners to maintain them properly (easier to replace the rack nylon bush) and because the rubber bushes on each end protect them from shock more than the ball joints on the 505 racks. There's also the fact that 604s have usually done less kms.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Apr 2001
    2,334
    Quote Originally Posted by jarrods
    The shaft is directly connected to the pinion via a torsion bar. The torsion bar allows a small amount of twist which inturn allows the direction control valving to function.
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    303
    Quote Originally Posted by davemcbean
    Dave
    This is what I thought, I just couldn't put it into words like Dave did (thanks). I believe the tortion bar on my rack was stretched (for want of a better word) by being forced to turn the wheels without the assistance of the ram, resulting in excessive play not just in the center but everywhere. This occured in a everyday road car driven over a period of 2 - 3 years and gradually got worse.
    Any other thoughts
    Jarrod
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    Im running the 6 with out pwr steer. I dumped the pwr and turned the valve around 180 degrees so I could fit the LHD bellhousing for the manual box.
    The steering is heavier , but it's not unbearable. It's even better now that i'm used to it .
    If you're going to do it just make sure you keep the valve lubricated.
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    Fellow Frogger! OddFireV6's Avatar
    153
    Jarrod
    Its unlikely that the vagueness you felt in your 504 was caused by the lack of the pump, there is a physical limit to how far the twist on the tortion bar can go, it is limited after a small amount as Dave said.
    OddfireV6
    504 V6 24V, 203
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Dave
    In my rally 504 I have fitted a 604 unassisted pwr steer rack but I ran a weld arround the top of the input shaft joining the torsion bar to the outer pinion shaft. I must say though that the "tee" flange must be included in the weld also as there is the posibility of the torsion bar breaking on the weld, (not good). This modification stopped all vagueness due to the torsion bar twisting.
    303
    Thanks guys.
    We might leave it as it is and see how it goes.
    Jarrod
