What's that noise in the 504?
    Apr 2002
    87
    Default What's that noise in the 504?
    Have encountered a strange noise emanating from inside the dashboard of my 504.
    Happens as the accelerator is applied and sounds like paper being crumpled.
    Sound stops when off the accelerator.
    Pretty certain it's not coming from under the bonnet?
    Discovered that the heater no longer works and not sure whether or not it may be related to the noise?
    Noise continues regardless whether the heater is on or off.
    Any ideas on this one?
    ______________________________
    Peter. 504 GL '75
    12,266
    Quote Originally Posted by PUG_504_505
    Peter. 504 GL '75
    could be air in the cooling system
    check by taking the cap off and running the engine to see if you have any air bubbles running around in the radiator
    water moves faster with engine speed so when you take your foot off the water flow slows down but to me it sounds like air
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    I had a leaf in an airvent that made a similar noise
    My fan when cold also makes a few odd noises.
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    Far North Queensland
    1,494
    My current 504 driver has a similar sound.
    Amazing what finds its way through the air outlet down into the heater.
    One car I stripped yielded about $6-00 worth of coins in the heater.
    Paul, 8 504s (three diesels) divorce registered wooohooo
    Fellow Frogger! zac505's Avatar
    Coffs Harbour, NSW, Australia
    226
    ...sounds like paper being crumpled.
    Peter.
    A buddy of mine had the same noise emanating from higher up in the dash of his 504 Familiale, just under the windscreen. When I quizzed him about it he said it was heater related. His heater still worked though. Perhaps yours is full of air.
    Sorry I have no answers for you, but it is obviously a common problem.
